Salta al contenuto principale
Lenovo IdeaPad Z570 Keyboard Replacement
Cosa ti serve
  1. Lenovo IdeaPad Z570 Keyboard Replacement, Battery: passo 1, immagine 1 di 1
    • Place the laptop face down with the battery facing away from you
  2. Lenovo IdeaPad Z570 Keyboard Replacement: passo 2, immagine 1 di 1
    • Flip the right switch right-bound
  3. Lenovo IdeaPad Z570 Keyboard Replacement: passo 3, immagine 1 di 1
    • Hold the left switch.
  4. Lenovo IdeaPad Z570 Keyboard Replacement: passo 4, immagine 1 di 2 Lenovo IdeaPad Z570 Keyboard Replacement: passo 4, immagine 2 di 2
    • Push the battery forward lightly to remove it while holding the left switch.
  5. Lenovo IdeaPad Z570 Keyboard Replacement, Disc Drive: passo 5, immagine 1 di 1
    • Place the laptop face down with the battery slot facing away from you.
  6. Lenovo IdeaPad Z570 Keyboard Replacement: passo 6, immagine 1 di 2 Lenovo IdeaPad Z570 Keyboard Replacement: passo 6, immagine 2 di 2
    • Loosen all seven 3mm screws from the back panel using a Phillips #0 screwdriver.
    • These screws cannot be removed from the device.
    • Remove the back panel from the device.
  7. Lenovo IdeaPad Z570 Keyboard Replacement: passo 7, immagine 1 di 2 Lenovo IdeaPad Z570 Keyboard Replacement: passo 7, immagine 2 di 2
    • Remove the 3 mm Phillips #0 screw located on the left hand side that holds the disc drive in place.
  8. Lenovo IdeaPad Z570 Keyboard Replacement: passo 8, immagine 1 di 2 Lenovo IdeaPad Z570 Keyboard Replacement: passo 8, immagine 2 di 2
    • Gently remove the disc drive from the left hand side of the laptop.
  9. Lenovo IdeaPad Z570 Keyboard Replacement, Keyboard: passo 9, immagine 1 di 3 Lenovo IdeaPad Z570 Keyboard Replacement, Keyboard: passo 9, immagine 2 di 3 Lenovo IdeaPad Z570 Keyboard Replacement, Keyboard: passo 9, immagine 3 di 3
    • Remove the three 12mm screws found near these symbols with a Phillips #0 screwdriver.
  10. Lenovo IdeaPad Z570 Keyboard Replacement: passo 10, immagine 1 di 1
    • Orient the laptop at a 90 degree angle with the keyboard being vertical and the screen horizontal to the surface you are working on.
  11. Lenovo IdeaPad Z570 Keyboard Replacement: passo 11, immagine 1 di 2 Lenovo IdeaPad Z570 Keyboard Replacement: passo 11, immagine 2 di 2
    • Pry the keyboard off staring from the corner where the “esc”” key is located using an opening tool.
    • Now orient the laptop in the standard position and take off the keyboard.
  12. Lenovo IdeaPad Z570 Keyboard Replacement: passo 12, immagine 1 di 3 Lenovo IdeaPad Z570 Keyboard Replacement: passo 12, immagine 2 di 3 Lenovo IdeaPad Z570 Keyboard Replacement: passo 12, immagine 3 di 3
    • At the terminal block, flip the black switch on the terminal up.
  13. Lenovo IdeaPad Z570 Keyboard Replacement: passo 13, immagine 1 di 2 Lenovo IdeaPad Z570 Keyboard Replacement: passo 13, immagine 2 di 2
    • Pull the keyboard out from the terminal block.
Conclusione
Altre 2 persone hanno completato questa guida.
Mya DeSantos
Membro da: 03/18/19
318 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 28
Tutti i Tempi: 1,181
