Salta al contenuto principale
Lenovo IdeaPad Yoga 13 WiFi Module Replacement
Cosa ti serve
  1. Lenovo IdeaPad Yoga 13 WiFi Module Replacement, Keyboard: passo 1, immagine 1 di 1
    • Power off your laptop before beginning disassembly.
    • Open the laptop to locate the keyboard.
  2. Lenovo IdeaPad Yoga 13 WiFi Module Replacement: passo 2, immagine 1 di 2 Lenovo IdeaPad Yoga 13 WiFi Module Replacement: passo 2, immagine 2 di 2
    • Insert a plastic opening tool in the seam between the keyboard and laptop body.
    • Carefully run the tool around the top and sides of the keyboard to pop out the 9 tabs holding in the keyboard.
  3. Lenovo IdeaPad Yoga 13 WiFi Module Replacement: passo 3, immagine 1 di 3 Lenovo IdeaPad Yoga 13 WiFi Module Replacement: passo 3, immagine 2 di 3 Lenovo IdeaPad Yoga 13 WiFi Module Replacement: passo 3, immagine 3 di 3
    • Lift the keyboard up, then pivot it towards you to lay it facedown on the trackpad and palm rests.
    • Be careful when lifting the keyboard up. The ribbon cable connecting it to the motherboard is very short, and the connector is fragile.
    • The top corners of the keyboard may be stuck to the laptop bezel with double sided tape. See rectangles in Image 3. Be careful as you lift the keyboard up and pivot it toward you.
  4. Lenovo IdeaPad Yoga 13 WiFi Module Replacement: passo 4, immagine 1 di 3 Lenovo IdeaPad Yoga 13 WiFi Module Replacement: passo 4, immagine 2 di 3 Lenovo IdeaPad Yoga 13 WiFi Module Replacement: passo 4, immagine 3 di 3
    • Locate the ribbon cable connecting the keyboard to the motherboard.
    • Use the tip of the opening tool to lift the black flap on the connector.
    • With the twezers, gently lift the ribbon cable out of the connector.
    • Be careful when reinserting the ribbon cable.
    • Ensure the cutouts on the end of the cable match the tabs on the connector.
  5. Lenovo IdeaPad Yoga 13 WiFi Module Replacement, Keyboard Bezel: passo 5, immagine 1 di 1
    • Locate and remove the screws holding the bezel to the laptop body:
    • Two 3 mm Phillips screws
    • Three 5.5 mm Phillips screws
  6. Lenovo IdeaPad Yoga 13 WiFi Module Replacement: passo 6, immagine 1 di 1
    • Flip the laptop over.
    • Locate and remove the screws holding the bezel to the bottom panel:
    • Ten 4.5 mm Phillips screws
  7. Lenovo IdeaPad Yoga 13 WiFi Module Replacement: passo 7, immagine 1 di 2 Lenovo IdeaPad Yoga 13 WiFi Module Replacement: passo 7, immagine 2 di 2
    • There is now nothing securing the bezel to the laptop body. However, there are still two cables connecting the bezel to the mainboard. Ensure the bezel remains in place until the cables are disconnected.
    • Flip the laptop back over.
    • Locate the small trackpad ribbon cable and use the opening tool to lift the black flap on the connector.
    • With tweezers, gently pull the ribbon cable out of the connector.
    • You can use the clear plastic tab on the top of the ribbon connector to help pull the cable out.
  8. Lenovo IdeaPad Yoga 13 WiFi Module Replacement: passo 8, immagine 1 di 1
    • Locate the power board cable and disconnect it by pulling the cable head towards the front of the laptop.
    • You can use a metal spudger to push the head out of the socket.
    • Be careful to not damage the socket.
  9. Lenovo IdeaPad Yoga 13 WiFi Module Replacement: passo 9, immagine 1 di 1
    • Lift the keyboard bezel off the laptop. The bezel is secured to the chassis by 10 plastic clips around the circumference that can be released with the plastic pry tool.
    • You may need to flip the screen around to get the necessary clearance at the hinges.
  10. Lenovo IdeaPad Yoga 13 WiFi Module Replacement, Battery: passo 10, immagine 1 di 1
    • Unplug the battery cable.
  11. Lenovo IdeaPad Yoga 13 WiFi Module Replacement: passo 11, immagine 1 di 1
    • Remove the screws holding the battery to the chassis:
    • Four 4 mm Philips screws
  12. Lenovo IdeaPad Yoga 13 WiFi Module Replacement: passo 12, immagine 1 di 1
    • Gently lift the battery out of the laptop.
    • Handle the battery carefully. Do not allow it to bend or be punctured.
  13. Lenovo IdeaPad Yoga 13 WiFi Module Replacement, WiFi Module: passo 13, immagine 1 di 1
    • Using the tweezers, unplug the gray and black antennae cables.
    • Be gentle: The cables are fragile.
  14. Lenovo IdeaPad Yoga 13 WiFi Module Replacement: passo 14, immagine 1 di 1
    • Using the tweezers, remove the ribbon cable connecting the WiFi module to the motherboard.
    • Be gentle: The ribbon cable and its connectors are fragile.
  15. Lenovo IdeaPad Yoga 13 WiFi Module Replacement: passo 15, immagine 1 di 1
    • Using the tweezers, lift up on the retaining tab of the module retention bracket and slide the bracket to the left, then lift it free.
  16. Lenovo IdeaPad Yoga 13 WiFi Module Replacement: passo 16, immagine 1 di 1
    • Gently lift the WiFi module out of the laptop.
Conclusione
Altre 10 persone hanno completato questa guida.
4 Commenti
I need to replace the wifi card in one of these laptops and I’d like to get a different brand. What is this form factor called?
deekstercaddy - Replica
Your tutorial is WONDERFUL, clear and precise. Thank you. Now I need to find a replacement for wifi card. Any suggestions? Thanks so much but I do need to get a new card and I am not finding it too easy to find. Take care and be safe.
Napicella - Replica
Is the Bluetooth a separate module to the wifi card?
batmanc - Replica
I have the same issue. Couldn’t find anything on the internet. My BT is defective, because it sometimes disables my mouse. This computer was a beautiful and well build, with the great touchscreen, but wireless connections are total mistake from the early beginning. The integrated wifi likes not to find any network. Since 2019 I’m working with the usb WiFi module bought on aliexpress. It is far better than the installed, but sticks out the chassis and took one port.
Romario997 -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 57
Tutti i Tempi: 8,911
