Salta al contenuto principale
Lenovo IdeaPad Yoga 11S Top Assembly Replacement
Cosa ti serve
  1. Lenovo IdeaPad Yoga 11S Top Assembly Replacement, Top Assembly: passo 1, immagine 1 di 3 Lenovo IdeaPad Yoga 11S Top Assembly Replacement, Top Assembly: passo 1, immagine 2 di 3 Lenovo IdeaPad Yoga 11S Top Assembly Replacement, Top Assembly: passo 1, immagine 3 di 3
    • Remember to power off the device before removing any parts.
    • Position the laptop so that the bottom enclosure is facing upward.
    • Use a Phillips #0 Screwdriver to remove the ten 1.9mm screws holding the bottom enclosure in place.
    • Use an opening tool to carefully pry up the rubber pads.
    • Use a Phillips screwdriver to remove the two screws under the rubber pads, which secure the keyboard.
  2. Lenovo IdeaPad Yoga 11S Top Assembly Replacement, Remove Keyboard: passo 2, immagine 1 di 1
    • Flip the laptop over and swing open the display.
    • Lift the edge of the keyboard closest to the trackpad up.
    • Carefully disconnect keyboard ribbon cable from the laptop.
    • Remove the keyboard.
  3. Lenovo IdeaPad Yoga 11S Top Assembly Replacement: passo 3, immagine 1 di 1
    • Remove the two screws securing the midframe.
  4. Lenovo IdeaPad Yoga 11S Top Assembly Replacement: passo 4, immagine 1 di 3 Lenovo IdeaPad Yoga 11S Top Assembly Replacement: passo 4, immagine 2 di 3 Lenovo IdeaPad Yoga 11S Top Assembly Replacement: passo 4, immagine 3 di 3
    • Grab the front edge of the top assembly and lift it up carefully.
    • There are three ribbon cables that attach the top assembly to the motherboard. Lift carefully to avoid damaging them.
    • Gently slide the three ribbon cables out of their slots.
    • Remove the top assembly completely by pulling it off of the device.
Conclusione
Altre 2 persone hanno completato questa guida.
Landon Epps
Membro da: 03/26/15
982 Reputazione
5 Guide realizzate
Baylor, Team 7-11, Williams Spring 2015 Membro di Baylor, Team 7-11, Williams Spring 2015
BU-WILLIAMS-S15S7G11
3 Membri
10 Guide realizzate
Un commento
I am looking into buying one of these but looking at your pictures I can't find the SSD. Is it user upgradeable?
ggr - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 12
Tutti i Tempi: 3,165
