Salta al contenuto principale
Lenovo IdeaPad Yoga 11S Display Replacement
Cosa ti serve
  1. Lenovo IdeaPad Yoga 11S Display Replacement, Top Assembly: passo 1, immagine 1 di 3 Lenovo IdeaPad Yoga 11S Display Replacement, Top Assembly: passo 1, immagine 2 di 3 Lenovo IdeaPad Yoga 11S Display Replacement, Top Assembly: passo 1, immagine 3 di 3
    • Remember to power off the device before removing any parts.
    • Position the laptop so that the bottom enclosure is facing upward.
    • Use a Phillips #0 Screwdriver to remove the ten 1.9mm screws holding the bottom enclosure in place.
    • Use an opening tool to carefully pry up the rubber pads.
    • Use a Phillips screwdriver to remove the two screws under the rubber pads, which secure the keyboard.
  2. Lenovo IdeaPad Yoga 11S Display Replacement, Remove Keyboard: passo 2, immagine 1 di 1
    • Flip the laptop over and swing open the display.
    • Lift the edge of the keyboard closest to the trackpad up.
    • Carefully disconnect keyboard ribbon cable from the laptop.
    • Remove the keyboard.
  3. Lenovo IdeaPad Yoga 11S Display Replacement: passo 3, immagine 1 di 1
    • Remove the two screws securing the midframe.
  4. Lenovo IdeaPad Yoga 11S Display Replacement: passo 4, immagine 1 di 3 Lenovo IdeaPad Yoga 11S Display Replacement: passo 4, immagine 2 di 3 Lenovo IdeaPad Yoga 11S Display Replacement: passo 4, immagine 3 di 3
    • Grab the front edge of the top assembly and lift it up carefully.
    • There are three ribbon cables that attach the top assembly to the motherboard. Lift carefully to avoid damaging them.
    • Gently slide the three ribbon cables out of their slots.
    • Remove the top assembly completely by pulling it off of the device.
  5. Lenovo IdeaPad Yoga 11S Display Replacement, Display: passo 5, immagine 1 di 1
    • Keep the device positioned where it sits on the bottom encasing with the display open.
    • Locate the four 1.9mm screws used to attach the display brackets to the bottom enclosure of the device.
    • Use a Phillips #00 Screwdriver to remove the four screws.
  6. Lenovo IdeaPad Yoga 11S Display Replacement: passo 6, immagine 1 di 1
    • Use a plastic opening tool to lift the retaining flap to disconnect the right display cable connector.
    • Gently pull the display cable out of the socket.
  7. Lenovo IdeaPad Yoga 11S Display Replacement: passo 7, immagine 1 di 1
    • Use a plastic opening tool to lift the retaining flap to disconnect the left display cable connector.
  8. Lenovo IdeaPad Yoga 11S Display Replacement: passo 8, immagine 1 di 1
    • Gently lift the display to detach it from the device.
Conclusione
Altre 5 persone hanno completato questa guida.
Landon Epps
Membro da: 03/26/15
982 Reputazione
5 Guide realizzate
Baylor, Team 7-11, Williams Spring 2015 Membro di Baylor, Team 7-11, Williams Spring 2015
BU-WILLIAMS-S15S7G11
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 18
Tutti i Tempi: 5,038
