Introduzione
If there is not enough RAM for the laptop to run, you will need to replace or add more RAM. Follow this guide to replace or add more RAM.
RAM is an important part of the laptop because it allows for easy access to information, do not enough RAM limits the laptop which can prevent it from turning on.
Cosa ti serve
Flip the laptop upside down so that the bottom is facing up.
Use a Phillips #0 screwdriver to remove the eleven screws (two 1.5 mm screws, one 0.3 mm screw, and eight 0.5 mm screws) that secure the bottom cover.
