Salta al contenuto principale
Lenovo IdeaPad Y700-15ACZ Battery Replacement
Cosa ti serve
  1. Lenovo IdeaPad Y700-15ACZ Battery Replacement, Battery: passo 1, immagine 1 di 2 Lenovo IdeaPad Y700-15ACZ Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Flip the laptop upside down so that the bottom is facing up.
    • Using the #0 Phillips screwdriver, unscrew the eleven Phillips #0 screws (two 1.5 mm screws, one 0.3 mm screw, and eight 0.5 mm screws) that attach the cover to the laptop.
  2. Lenovo IdeaPad Y700-15ACZ Battery Replacement: passo 2, immagine 1 di 1
    • After removing the eleven Phillips #0 screws (two 1.5 mm screws, one 0.3 mm screw, and eight 0.5 mm screws), use the Jimmy to pop up the cover and remove it from the laptop.
  3. Lenovo IdeaPad Y700-15ACZ Battery Replacement: passo 3, immagine 1 di 2 Lenovo IdeaPad Y700-15ACZ Battery Replacement: passo 3, immagine 2 di 2
    • Find the battery connection above the battery.
    • Unplug the battery from the motherboard.
  4. Lenovo IdeaPad Y700-15ACZ Battery Replacement: passo 4, immagine 1 di 3 Lenovo IdeaPad Y700-15ACZ Battery Replacement: passo 4, immagine 2 di 3 Lenovo IdeaPad Y700-15ACZ Battery Replacement: passo 4, immagine 3 di 3
    • Unscrew the 0.5 mm screws from battery connected to the motherboard with the #0 Philips screwdriver.
    • Gently lift the battery from the laptop and replace the battery.
Conclusione
Kevin
Membro da: 09/28/22
351 Reputazione
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 21
Tutti i Tempi: 775
