Salta al contenuto principale
Lenovo IdeaPad Y580-2099 Wi-Fi Card Replacement
Cosa ti serve
  1. Lenovo IdeaPad Y580-2099 Wi-Fi Card Replacement, Wi-Fi Card: passo 1, immagine 1 di 1
    • Make sure the laptop is powered off and disconnected from the charger.
    • Flip the laptop upside down so that the bottom faces up.
  2. Lenovo IdeaPad Y580-2099 Wi-Fi Card Replacement: passo 2, immagine 1 di 1
    • Place your thumbs on each side of the laptop and slide the tabs into the unlock position.
  3. Lenovo IdeaPad Y580-2099 Wi-Fi Card Replacement: passo 3, immagine 1 di 1
    • Once tabs are in the unlock position, carefully slide the battery out of the compartment.
  4. Lenovo IdeaPad Y580-2099 Wi-Fi Card Replacement: passo 4, immagine 1 di 1
    • Use a Phillips #0 screwdriver to unscrew and remove the two 8 mm screws (highlighted in red) that secure the back panel in place.
  5. Lenovo IdeaPad Y580-2099 Wi-Fi Card Replacement: passo 5, immagine 1 di 1
    • Gently slide & pull the panel off the device.
  6. Lenovo IdeaPad Y580-2099 Wi-Fi Card Replacement: passo 6, immagine 1 di 2 Lenovo IdeaPad Y580-2099 Wi-Fi Card Replacement: passo 6, immagine 2 di 2
    • Use a Phillips #00 screwdriver to remove the two 3 mm screws that secure the Wi-Fi card in place.
  7. Lenovo IdeaPad Y580-2099 Wi-Fi Card Replacement: passo 7, immagine 1 di 1
    • Gently unplug the two coaxial antenna cables clasped to the Wi-Fi card.
  8. Lenovo IdeaPad Y580-2099 Wi-Fi Card Replacement: passo 8, immagine 1 di 1
    • Gently remove the old Wi-Fi card from the device.
Conclusione
Jeryn Fast
Membro da: 04/12/22
421 Reputazione
3 Guide realizzate
IUPUI, Team 1-1, Beck Spring 2022 Membro di IUPUI, Team 1-1, Beck Spring 2022
IUPUI-BECK-S22S1G1
3 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 13
Tutti i Tempi: 291
