Salta al contenuto principale
Lenovo IdeaPad Y580-2099 Motherboard Replacement
Cosa ti serve
  1. Lenovo IdeaPad Y580-2099 Motherboard Replacement, Battery: passo 1, immagine 1 di 1
    • Slide out both locks for the battery, located on the back of the device.
  2. Lenovo IdeaPad Y580-2099 Motherboard Replacement: passo 2, immagine 1 di 2 Lenovo IdeaPad Y580-2099 Motherboard Replacement: passo 2, immagine 2 di 2
    • Remove the battery.
  3. Lenovo IdeaPad Y580-2099 Motherboard Replacement, Keyboard: passo 3, immagine 1 di 2 Lenovo IdeaPad Y580-2099 Motherboard Replacement, Keyboard: passo 3, immagine 2 di 2
    • Unscrew the 2 screws on the bottom of the device.
    • Slide the back panel out.
  4. Lenovo IdeaPad Y580-2099 Motherboard Replacement: passo 4, immagine 1 di 1
    • Unscrew the 3 "keyboard" detected screws.
  5. Lenovo IdeaPad Y580-2099 Motherboard Replacement: passo 5, immagine 1 di 2 Lenovo IdeaPad Y580-2099 Motherboard Replacement: passo 5, immagine 2 di 2
    • Flip the laptop over and open up.
    • Then pry up the whole keyboard using the spudger.
    • Make sure to use a plastic spudger. You could damage the device using anything else.
    • Make sure not to take the frame that goes around the keys off. This part is not removable.
  6. Lenovo IdeaPad Y580-2099 Motherboard Replacement, Motherboard: passo 6, immagine 1 di 3 Lenovo IdeaPad Y580-2099 Motherboard Replacement, Motherboard: passo 6, immagine 2 di 3 Lenovo IdeaPad Y580-2099 Motherboard Replacement, Motherboard: passo 6, immagine 3 di 3
    • Flip laptop back over and unscrew the disc drive screw.
    • Remove the disc drive.
    • Unscrew all of the screws on the back of the device.
  7. Lenovo IdeaPad Y580-2099 Motherboard Replacement: passo 7, immagine 1 di 3 Lenovo IdeaPad Y580-2099 Motherboard Replacement: passo 7, immagine 2 di 3 Lenovo IdeaPad Y580-2099 Motherboard Replacement: passo 7, immagine 3 di 3
    • Flip the device over.
    • Unplug the two wires, as shown in the images.
    • Lift up on the keyboard bezel.
    • The bezel should come up easy, if not go back and make sure all screws have been removed.
  8. Lenovo IdeaPad Y580-2099 Motherboard Replacement: passo 8, immagine 1 di 2 Lenovo IdeaPad Y580-2099 Motherboard Replacement: passo 8, immagine 2 di 2
    • Unscrew the screws on the motherboard.
    • Disconnect the three connectors the two black and one white.
  9. Lenovo IdeaPad Y580-2099 Motherboard Replacement: passo 9, immagine 1 di 1
    • Carefully lift up the motherboard.
    • Unplug the wires underneath the motherboard.
    • Be careful not to rip the wires underneath the motherboard while lifting it up.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 21
Tutti i Tempi: 1,556
