Salta al contenuto principale
Lenovo IdeaPad Y580-2099 Daughterboard Replacement
Cosa ti serve
  1. Lenovo IdeaPad Y580-2099 Daughterboard Replacement, Battery: passo 1, immagine 1 di 1
    • Slide out both locks for the battery, located on the back of the device.
  2. Lenovo IdeaPad Y580-2099 Daughterboard Replacement: passo 2, immagine 1 di 2 Lenovo IdeaPad Y580-2099 Daughterboard Replacement: passo 2, immagine 2 di 2
    • Remove the battery.
  3. Lenovo IdeaPad Y580-2099 Daughterboard Replacement, Keyboard: passo 3, immagine 1 di 2 Lenovo IdeaPad Y580-2099 Daughterboard Replacement, Keyboard: passo 3, immagine 2 di 2
    • Unscrew the 2 screws on the bottom of the device.
    • Slide the back panel out.
  4. Lenovo IdeaPad Y580-2099 Daughterboard Replacement: passo 4, immagine 1 di 1
    • Unscrew the 3 "keyboard" detected screws.
  5. Lenovo IdeaPad Y580-2099 Daughterboard Replacement: passo 5, immagine 1 di 2 Lenovo IdeaPad Y580-2099 Daughterboard Replacement: passo 5, immagine 2 di 2
    • Flip the laptop over and open up.
    • Then pry up the whole keyboard using the spudger.
    • Make sure to use a plastic spudger. You could damage the device using anything else.
    • Make sure not to take the frame that goes around the keys off. This part is not removable.
  6. Lenovo IdeaPad Y580-2099 Daughterboard Replacement, Daughterboard: passo 6, immagine 1 di 1
    • Use a Phillips #0 screwdriver to remove the 16 screws highlighted. There are 12 M2.5 x 8 mm long screws, and 4 M2 x 2 mm long screws.
    • Use a Phillips #0 screwdriver to remove the 10 mm screw (highlighted in orange) that secures the disc drive.
    • Quickly survey and make sure all screws on the back panel are removed from the device.
    • Some of the screws may have been removed in previous steps.
  7. Lenovo IdeaPad Y580-2099 Daughterboard Replacement: passo 7, immagine 1 di 1
    • Carefully slide the disc drive out.
  8. Lenovo IdeaPad Y580-2099 Daughterboard Replacement: passo 8, immagine 1 di 1
    • Use a Phillips #0 screwdriver to remove the three M2 x 3 mm long screws circled in red.
  9. Lenovo IdeaPad Y580-2099 Daughterboard Replacement: passo 9, immagine 1 di 1
    • Lift open the top panel carefully as there are wire cables secured to the motherboard.
  10. Lenovo IdeaPad Y580-2099 Daughterboard Replacement: passo 10, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • After locating the cable holding the top panel in place, carefully unhook the handle using precision tweezers.
    • Carefully remove the top plate.
  11. Lenovo IdeaPad Y580-2099 Daughterboard Replacement: passo 11, immagine 1 di 1
    • Now that the top plate is removed, locate the daughter board. (Highlighted in Red).
  12. Lenovo IdeaPad Y580-2099 Daughterboard Replacement: passo 12, immagine 1 di 1
    • Use a plastic spudger or precision tweezers to carefully unhook the daughterboard cables.
  13. Lenovo IdeaPad Y580-2099 Daughterboard Replacement: passo 13, immagine 1 di 1
    • Use a Phillips #0 screwdriver to remove the two M2.5 x 3 mm long screws that secure the daughterboard.
  14. Lenovo IdeaPad Y580-2099 Daughterboard Replacement: passo 14, immagine 1 di 1
    • Check and make sure all screws and cable wires are detached before attempting to remove the daughterboard.
    • Carefully remove the daughterboard.
Conclusione
Jeryn Fast
Membro da: 04/12/22
421 Reputazione
3 Guide realizzate
IUPUI, Team 1-1, Beck Spring 2022 Membro di IUPUI, Team 1-1, Beck Spring 2022
IUPUI-BECK-S22S1G1
3 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 152
