Salta al contenuto principale
Lenovo IdeaPad U530 Touch Fan Replacement
Cosa ti serve
  1. Lenovo IdeaPad U530 Touch Fan Replacement, Battery: passo 1, immagine 1 di 3 Lenovo IdeaPad U530 Touch Fan Replacement, Battery: passo 1, immagine 2 di 3 Lenovo IdeaPad U530 Touch Fan Replacement, Battery: passo 1, immagine 3 di 3
    • Remove the back panel by removing all screws. Use a PH000 screwdriver head.
    • Make sure to also remove the hinge screws.
  2. Lenovo IdeaPad U530 Touch Fan Replacement: passo 2, immagine 1 di 2 Lenovo IdeaPad U530 Touch Fan Replacement: passo 2, immagine 2 di 2
    • To remove the panel, use a plastic opening tool to prevent any damage.
  3. Lenovo IdeaPad U530 Touch Fan Replacement: passo 3, immagine 1 di 1
    • Locate and assess the battery. Pictured in the upper right area of the computer.
  4. Lenovo IdeaPad U530 Touch Fan Replacement: passo 4, immagine 1 di 2 Lenovo IdeaPad U530 Touch Fan Replacement: passo 4, immagine 2 di 2
    • Locate and remove all screws attaching the battery to the hull of the computer. It is recommended that you use a JIS #1 screwdriver head for this task.
    • Be careful to keep track of all removed screws.
  5. Lenovo IdeaPad U530 Touch Fan Replacement: passo 5, immagine 1 di 1
    • Detach the connection from the battery to the motherboard. This is the only connection that needs to be disconnected for the battery.
    • To remove the connection, please pull firmly, as it well secured.
  6. Lenovo IdeaPad U530 Touch Fan Replacement: passo 6, immagine 1 di 1
    • Simply lift the battery out of the computer, and acquire a replacement.
  7. Lenovo IdeaPad U530 Touch Fan Replacement, Fan: passo 7, immagine 1 di 3 Lenovo IdeaPad U530 Touch Fan Replacement, Fan: passo 7, immagine 2 di 3 Lenovo IdeaPad U530 Touch Fan Replacement, Fan: passo 7, immagine 3 di 3
    • Remove the six 3 mm screws from the fan using a JIS #1 screwdriver.
  8. Lenovo IdeaPad U530 Touch Fan Replacement: passo 8, immagine 1 di 2 Lenovo IdeaPad U530 Touch Fan Replacement: passo 8, immagine 2 di 2
    • Disconnect the connecter cords from the fan and remove the fan.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 187
