Salta al contenuto principale
Lenovo IdeaPad U430 Touch Wifi Card Replacement
Cosa ti serve
  1. Lenovo IdeaPad U430 Touch Wifi Card Replacement, Bottom Cover: passo 1, immagine 1 di 1
    • Power off your computer before you begin.
    • Find and remove the 10 Phillips style body screws on the bottom of the laptop case.
    • Remove 2 screws, 1 located on the left hinge cover and one located on the right hinge cover.
  2. Lenovo IdeaPad U430 Touch Wifi Card Replacement: passo 3, immagine 1 di 2 Lenovo IdeaPad U430 Touch Wifi Card Replacement: passo 3, immagine 2 di 2
    • Starting from the front, use a plastic opening tool to separate the bottom of the case from the body of the laptop.
  3. Lenovo IdeaPad U430 Touch Wifi Card Replacement, Wifi Card: passo 4, immagine 1 di 1
    • Remove the two 2.8mm screws using the Phillips #0 screwdriver.
  4. Lenovo IdeaPad U430 Touch Wifi Card Replacement: passo 5, immagine 1 di 2 Lenovo IdeaPad U430 Touch Wifi Card Replacement: passo 5, immagine 2 di 2
    • Remove the two snap cables connecting the wifi card to the rest of the computer.
  5. Lenovo IdeaPad U430 Touch Wifi Card Replacement: passo 6, immagine 1 di 1
    • Slide the Wifi card away from the Wifi card connector.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 606
