Salta al contenuto principale
Lenovo IdeaPad U430 Touch Speaker Replacement
Cosa ti serve
  1. Lenovo IdeaPad U430 Touch Speaker Replacement, Bottom Cover: passo 1, immagine 1 di 1
    • Power off your computer before you begin.
    • Find and remove the 10 Phillips style body screws on the bottom of the laptop case.
    • Remove 2 screws, 1 located on the left hinge cover and one located on the right hinge cover.
  2. Lenovo IdeaPad U430 Touch Speaker Replacement: passo 3, immagine 1 di 2 Lenovo IdeaPad U430 Touch Speaker Replacement: passo 3, immagine 2 di 2
    • Starting from the front, use a plastic opening tool to separate the bottom of the case from the body of the laptop.
  3. Lenovo IdeaPad U430 Touch Speaker Replacement, Speaker: passo 4, immagine 1 di 1
    • Disconnect the speaker cable connectors from the motherboard and/or USB board.
  4. Lenovo IdeaPad U430 Touch Speaker Replacement: passo 5, immagine 1 di 2 Lenovo IdeaPad U430 Touch Speaker Replacement: passo 5, immagine 2 di 2
    • Unscrew the two 6.5mm screws from each speaker with a PH1 Phillips head screwdriver.
  5. Lenovo IdeaPad U430 Touch Speaker Replacement: passo 6, immagine 1 di 2 Lenovo IdeaPad U430 Touch Speaker Replacement: passo 6, immagine 2 di 2
    • Remove and replace the speaker.
Conclusione
USF Tampa, Team S2-G6, Nance Spring 2017 Membro di USF Tampa, Team S2-G6, Nance Spring 2017
USFT-NANCE-S17S2G6
3 Membri
15 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 567
