Salta al contenuto principale
Lenovo IdeaPad U430 Touch Screen Replacement
Cosa ti serve
  1. Lenovo IdeaPad U430 Touch Screen Replacement, Bottom Cover: passo 1, immagine 1 di 1
    • Power off your computer before you begin.
    • Find and remove the 10 Phillips style body screws on the bottom of the laptop case.
    • Remove 2 screws, 1 located on the left hinge cover and one located on the right hinge cover.
  2. Lenovo IdeaPad U430 Touch Screen Replacement: passo 3, immagine 1 di 2 Lenovo IdeaPad U430 Touch Screen Replacement: passo 3, immagine 2 di 2
    • Starting from the front, use a plastic opening tool to separate the bottom of the case from the body of the laptop.
  3. Lenovo IdeaPad U430 Touch Screen Replacement, Touch Screen: passo 4, immagine 1 di 2 Lenovo IdeaPad U430 Touch Screen Replacement, Touch Screen: passo 4, immagine 2 di 2
    • Remove the four 4.5mm screws from the screen hinges.
  4. Lenovo IdeaPad U430 Touch Screen Replacement: passo 5, immagine 1 di 1
    • Use the plastic spudger to lift and disconnect the antennae connectors from the motherboard.
  5. Lenovo IdeaPad U430 Touch Screen Replacement: passo 6, immagine 1 di 1
    • Use fingers to remove the bundled cable connector for the front facing camera.
  6. Lenovo IdeaPad U430 Touch Screen Replacement: passo 7, immagine 1 di 1
    • Use the plastic opening tool or spudger to lift and remove the flat top connector from the motherboard.
  7. Lenovo IdeaPad U430 Touch Screen Replacement: passo 8, immagine 1 di 1
    • Carefully separate the bottom of the laptop from the screen.
  8. Lenovo IdeaPad U430 Touch Screen Replacement: passo 9, immagine 1 di 3 Lenovo IdeaPad U430 Touch Screen Replacement: passo 9, immagine 2 di 3 Lenovo IdeaPad U430 Touch Screen Replacement: passo 9, immagine 3 di 3
    • Using the spudger and the plastic opening tool, carefully remove the plastic cover from the bottom of the screen.
    • Plastic clips can be fragile, so take your time to carefully remove.
  9. Lenovo IdeaPad U430 Touch Screen Replacement: passo 10, immagine 1 di 1
    • Using the PH1 Phillips head, remove the 3mm screws from the left side screen hinge on the screen assembly.
    • Remove the hinge.
    • Using the PH000 Phillips head screwdriver, remove the three 2mm screws that are securing the bottom of the screen.
    • Using the plastic opening tool and the plastic spudger, work your way around the screen to release it from the case.
    • Remove the screen.
Conclusione
Altre 4 persone hanno completato questa guida.
USF Tampa, Team S2-G6, Nance Spring 2017 Membro di USF Tampa, Team S2-G6, Nance Spring 2017
USFT-NANCE-S17S2G6
3 Membri
15 Guide realizzate
2 Commenti
I found this guide very helpful and was able to remove an old cover with a damaged hinge attachment and replace it with a new one.
When I started the laptop back up and tested it, however, the computer couldn’t find the camera. I followed the advice for troubleshooting the camera, including ‘Scan for hardware changes,’ but it the camera still doesn’t show up in Device Manager.
I hasten to say yes, I DID plug the new camera into the connector on the computer.
Interestingly enough, when I plug the old camera into the connector, the computer finds the camera and it works just fine!
Has anyone else run into this problem? If so, is there a fix for it?
Jonathan Wheeler - Replica
If you get a new cover, it probably will not have the camera and microphone array assembly, though it probably will have the cable for it. The camera assembly is at the top of the cover and is held on with a light adhesive. You will have to unplug it and carefully pry it up, then install it the same way in the new cover.
Luke Hamaty - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 10
Tutti i Tempi: 5,378
