Salta al contenuto principale
Ricambi
Nessuna parte specificata.
  1. Power off your computer before you begin.
    • Power off your computer before you begin.
    • Find and remove the 10 Phillips style body screws on the bottom of the laptop case.
    • Remove 2 screws, 1 located on the left hinge cover and one located on the right hinge cover.
  2. Starting from the front, use a plastic opening tool to separate the bottom of the case from the body of the laptop. Starting from the front, use a plastic opening tool to separate the bottom of the case from the body of the laptop.
    • Starting from the front, use a plastic opening tool to separate the bottom of the case from the body of the laptop.
Conclusione
Patrick Ripkey
Membro da: 28/02/2017
627 Reputazione
5 Guide realizzate
USF Tampa, Team S2-G6, Nance Spring 2017 Membro di USF Tampa, Team S2-G6, Nance Spring 2017
USFT-NANCE-S17S2G6
3 Membri
15 Guide realizzate
Un commento
When removing the cover, be careful: There are a few (two or three?) plastic hooks that break easily in the area around the ports and the SD slot. (It's no big deal if they do break, but you can avoid it.)
Tom Janson - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 18
Tutti i Tempi: 2,443
