Salta al contenuto principale
Lenovo IdeaPad U410 Screen Replacement
Cosa ti serve
  1. Lenovo IdeaPad U410 Screen Replacement, Screen: passo 1, immagine 1 di 2 Lenovo IdeaPad U410 Screen Replacement, Screen: passo 1, immagine 2 di 2
    • Make sure your laptop is turned off before disassembling.
    • Power off the laptop.
    • Using the metal spudger, gently pry off the black trim around the screen.
    • Metal spudger can be used, but using your hand will prevent the screen and the plastic border from any damage.
  2. Lenovo IdeaPad U410 Screen Replacement: passo 2, immagine 1 di 2 Lenovo IdeaPad U410 Screen Replacement: passo 2, immagine 2 di 2
    • Remove the six 3 mm Phillips #1 screws holding the screen to the laptop.
    • Ignore the "Do not touch" label on the bottom portion of the screen. It will not damage the laptop.
  3. Lenovo IdeaPad U410 Screen Replacement: passo 3, immagine 1 di 3 Lenovo IdeaPad U410 Screen Replacement: passo 3, immagine 2 di 3 Lenovo IdeaPad U410 Screen Replacement: passo 3, immagine 3 di 3
    • Lower LCD screen onto the keyboard.
    • Find the gold connector on the bottom of the LCD panel.
    • Gently grab the connector on both sides and pull the connector straight out.
    • Connector cable is very fragile. Use the least amount of force possible.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 21
Tutti i Tempi: 1,481
