Salta al contenuto principale
Lenovo IdeaPad U350 RAM Replacement
Cosa ti serve
  1. Lenovo IdeaPad U350 RAM Replacement, RAM: passo 1, immagine 1 di 1
    • Unscrew the six screws on the back panel of the laptop using a PH1 Phillips bit.
    • These screws are 4.7mm long with a head diameter of 3.68mm.
    • The screws are attached to the panel. When unscrewing be sure to stop when you hear a click.
  2. Lenovo IdeaPad U350 RAM Replacement: passo 2, immagine 1 di 1
    • Gently lift the back panel from the side closest to the battery and remove panel
  3. Lenovo IdeaPad U350 RAM Replacement: passo 3, immagine 1 di 1
    • Push retention clips outward and then gently slide out of slot
  4. Lenovo IdeaPad U350 RAM Replacement: passo 4, immagine 1 di 1
    • Remove white and black wires to make room to remove the second RAM module.
  5. Lenovo IdeaPad U350 RAM Replacement: passo 5, immagine 1 di 1
    • Just like RAM Module 1, push retention clips outward and gently slide out the RAM Module.
    • When re-installing RAM modules, be sure to insert them at a 45 degree angle. This is the same angle that they should pop up to after the retention clips are pushed outward.
Conclusione
James Morizzo
Membro da: 09/29/14
496 Reputazione
3 Guide realizzate
USF Tampa, Team 1-4, Hickman Fall 2014 Membro di USF Tampa, Team 1-4, Hickman Fall 2014
USFT-HICKMAN-F14S1G4
3 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 17
Tutti i Tempi: 971
