Salta al contenuto principale
Lenovo IdeaPad U350 Hard Drive Replacement
Cosa ti serve
  1. Lenovo IdeaPad U350 Hard Drive Replacement, Hard Drive: passo 1, immagine 1 di 1
    • Unscrew the six screws on the back panel of the laptop using a PH1 Phillips bit.
    • These screws are attached to the panel. When unscrewing, be sure to stop when you here a click.
  2. Lenovo IdeaPad U350 Hard Drive Replacement: passo 2, immagine 1 di 1
    • Lift the back panel from the side closest to the battery and remove the panel.
  3. Lenovo IdeaPad U350 Hard Drive Replacement: passo 3, immagine 1 di 2 Lenovo IdeaPad U350 Hard Drive Replacement: passo 3, immagine 2 di 2
    • Slide the hard drive to the right, away from the RAM modules.
    • Lift the hard drive from the side closest to the RAM modules.
    • When re-inserting the hard drive, ensure that the copper contacts on the drive's connector are facing upwards.
Conclusione
James Morizzo
Membro da: 09/29/14
496 Reputazione
3 Guide realizzate
USF Tampa, Team 1-4, Hickman Fall 2014 Membro di USF Tampa, Team 1-4, Hickman Fall 2014
USFT-HICKMAN-F14S1G4
3 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 15
Tutti i Tempi: 1,788
