Salta al contenuto principale
Lenovo IdeaPad S400 Touch Speakers Replacement
Cosa ti serve
  1. Lenovo IdeaPad S400 Touch Speakers Replacement, Battery: passo 1, immagine 1 di 3 Lenovo IdeaPad S400 Touch Speakers Replacement, Battery: passo 1, immagine 2 di 3 Lenovo IdeaPad S400 Touch Speakers Replacement, Battery: passo 1, immagine 3 di 3
    • Turn your computer over so the back is face up.
    • Use your forefinger to unlock the two tabs located on the back. Slide the tabs until you see the red showing.
    • The battery cover will then pop up allowing you access to the battery.
  2. Lenovo IdeaPad S400 Touch Speakers Replacement, Speakers: passo 2, immagine 1 di 3 Lenovo IdeaPad S400 Touch Speakers Replacement, Speakers: passo 2, immagine 2 di 3 Lenovo IdeaPad S400 Touch Speakers Replacement, Speakers: passo 2, immagine 3 di 3
    • Remove the five 6mm Phillips #0 screws from the back panel.
    • Pull back the rubber tabs from the corners of the laptop backing to expose the screws.
    • The two tabs next to battery flip toward the battery. The two remaining tabs flip down, away from the battery.
    • Remove the four 4mm Phillips #0 screws that are underneath the rubber tabs.
    • Remove the three 6mm Phillips #0 screws from under the battery.
  3. Lenovo IdeaPad S400 Touch Speakers Replacement: passo 3, immagine 1 di 1
    • Slide the back panel away to remove it.
    • Don't be afraid to apply force when removing the back panel.
  4. Lenovo IdeaPad S400 Touch Speakers Replacement: passo 4, immagine 1 di 3 Lenovo IdeaPad S400 Touch Speakers Replacement: passo 4, immagine 2 di 3 Lenovo IdeaPad S400 Touch Speakers Replacement: passo 4, immagine 3 di 3
    • Remove the two 2mm Phillips #0 screws from each speaker.
    • Take the speakers off the base.
    • Pull the connecting cable from the motherboard, which will release the speakers.
    • To install the replacement speakers, follow these steps in reverse order.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 167
