Salta al contenuto principale
Lenovo IdeaPad S340-15IWL Motherboard Replacement
Cosa ti serve
  1. Lenovo IdeaPad S340-15IWL Motherboard Replacement, Back Panel: passo 1, immagine 1 di 2 Lenovo IdeaPad S340-15IWL Motherboard Replacement, Back Panel: passo 1, immagine 2 di 2
    • Power off the laptop and place it face-down on a non-scratching surface.
    • Using a Torx T5 screwdriver head, remove all ten 6 mm screws holding the back panel in place.
  2. Lenovo IdeaPad S340-15IWL Motherboard Replacement: passo 2, immagine 1 di 1
    • Slide a plastic opening tool underneath the back case near the screen hinges.
    • Gently pry up on either side of the case.
    • You may hear popping sounds as you pry up the back case. This is normal. If the case does not open, try prying at a different angle/position.
  3. Lenovo IdeaPad S340-15IWL Motherboard Replacement, Battery: passo 3, immagine 1 di 2 Lenovo IdeaPad S340-15IWL Motherboard Replacement, Battery: passo 3, immagine 2 di 2
    • Disconnect the battery cable by gently pulling it straight out of the connector.
    • Be sure to pull parallel to the device to avoid bending the motherboard connector.
    • The battery connector does not lock and only requires light pressure to insert and remove.
    • Remove the battery from the laptop.
  4. Lenovo IdeaPad S340-15IWL Motherboard Replacement, Fan: passo 4, immagine 1 di 1
    • Remove the two 3 mm screws connecting the fan to the casing using a Phillips #0 screwdriver.
  5. Lenovo IdeaPad S340-15IWL Motherboard Replacement: passo 5, immagine 1 di 2 Lenovo IdeaPad S340-15IWL Motherboard Replacement: passo 5, immagine 2 di 2
    • Using a spudger, gently disconnect the fan's cable from the motherboard.
  6. Lenovo IdeaPad S340-15IWL Motherboard Replacement: passo 6, immagine 1 di 1
    • Carefully unwind the black cable that runs between the top of the battery and the bottom of the fan from the grooves along the side of the fan.
    • In order to do so, you will need to pull up the metallic tape that holds the cable in place using either your fingers or a plastic prying tool to lift up the edge.
    • If you attempt to remove the device’s fan without removing the battery, the black cable may be wedged underneath the top of the battery. In this scenario, it is recommended that you at least loosen the screws holding the battery in place to allow for the cable to be removed with less resistance.
  7. Lenovo IdeaPad S340-15IWL Motherboard Replacement: passo 7, immagine 1 di 3 Lenovo IdeaPad S340-15IWL Motherboard Replacement: passo 7, immagine 2 di 3 Lenovo IdeaPad S340-15IWL Motherboard Replacement: passo 7, immagine 3 di 3
    • Carefully pick up the fan by the corners and detach the small connector wire by pulling parallel to the device.
    • Remove the fan from the laptop.
  8. Lenovo IdeaPad S340-15IWL Motherboard Replacement, Speakers: passo 8, immagine 1 di 3 Lenovo IdeaPad S340-15IWL Motherboard Replacement, Speakers: passo 8, immagine 2 di 3 Lenovo IdeaPad S340-15IWL Motherboard Replacement, Speakers: passo 8, immagine 3 di 3
    • Unplug the wire connecting the speakers to the motherboard.
    • Remove the speakers from each side of the laptop.
  9. Lenovo IdeaPad S340-15IWL Motherboard Replacement, Hard Drive: passo 9, immagine 1 di 3 Lenovo IdeaPad S340-15IWL Motherboard Replacement, Hard Drive: passo 9, immagine 2 di 3 Lenovo IdeaPad S340-15IWL Motherboard Replacement, Hard Drive: passo 9, immagine 3 di 3
    • Remove the four 3 mm screws holding the hard drive expansion slot in place using a Phillips #0 screwdriver.
  10. Lenovo IdeaPad S340-15IWL Motherboard Replacement, RAM: passo 10, immagine 1 di 2 Lenovo IdeaPad S340-15IWL Motherboard Replacement, RAM: passo 10, immagine 2 di 2
    • Using the opening tool, gently pop off the metal cover for the RAM stick.
  11. Lenovo IdeaPad S340-15IWL Motherboard Replacement: passo 11, immagine 1 di 2 Lenovo IdeaPad S340-15IWL Motherboard Replacement: passo 11, immagine 2 di 2
    • Using your thumbs, gently pull the two metal prongs that secure the RAM outwards.
    • The RAM will pop up at an angle.
    • Remove the RAM from the laptop.
  12. Lenovo IdeaPad S340-15IWL Motherboard Replacement, Heat Sink: passo 12, immagine 1 di 3 Lenovo IdeaPad S340-15IWL Motherboard Replacement, Heat Sink: passo 12, immagine 2 di 3 Lenovo IdeaPad S340-15IWL Motherboard Replacement, Heat Sink: passo 12, immagine 3 di 3
    • Remove the three 3 mm screws that secure the black heat sink near the top of the computer using a Phillips #0 screwdriver.
    • Lift the heat sink vertically to remove it from the laptop.
  13. Lenovo IdeaPad S340-15IWL Motherboard Replacement, Video Cable: passo 13, immagine 1 di 3 Lenovo IdeaPad S340-15IWL Motherboard Replacement, Video Cable: passo 13, immagine 2 di 3 Lenovo IdeaPad S340-15IWL Motherboard Replacement, Video Cable: passo 13, immagine 3 di 3
    • Using an opening tool, carefully flip up the retaining flaps holding the silver video cable in place.
    • Slide the ribbon cable out of each connector.
  14. Lenovo IdeaPad S340-15IWL Motherboard Replacement, Wi-Fi Card: passo 14, immagine 1 di 2 Lenovo IdeaPad S340-15IWL Motherboard Replacement, Wi-Fi Card: passo 14, immagine 2 di 2
    • Pull up the black foam adhesive that covers the screw and connectors holding the Wi-Fi card in place.
  15. Lenovo IdeaPad S340-15IWL Motherboard Replacement: passo 15, immagine 1 di 2 Lenovo IdeaPad S340-15IWL Motherboard Replacement: passo 15, immagine 2 di 2
    • Using an opening tool, lift up on the black and white coaxial cables on the Wi-Fi card and gently pull upward to unplug them.
    • When reconnecting the cables, be sure to match the colors to the arrows on the Wi-Fi card.
  16. Lenovo IdeaPad S340-15IWL Motherboard Replacement: passo 16, immagine 1 di 2 Lenovo IdeaPad S340-15IWL Motherboard Replacement: passo 16, immagine 2 di 2
    • Remove the single 3 mm screw holding the Wi-Fi card in place using a Phillips #0 screwdriver.
    • Gently lift the Wi-Fi card out of the computer.
  17. Lenovo IdeaPad S340-15IWL Motherboard Replacement, Motherboard: passo 17, immagine 1 di 3 Lenovo IdeaPad S340-15IWL Motherboard Replacement, Motherboard: passo 17, immagine 2 di 3 Lenovo IdeaPad S340-15IWL Motherboard Replacement, Motherboard: passo 17, immagine 3 di 3
    • Using an opening tool, flip up the retaining flap that holds the connector to the thin black ribbon cable at the bottom of the motherboard.
    • Gently remove the ribbon cable from its connector.
    • The cable is folded over and connected to itself with an adhesive. Be careful to only pull at the top fold of the cable.
  18. Lenovo IdeaPad S340-15IWL Motherboard Replacement: passo 18, immagine 1 di 2 Lenovo IdeaPad S340-15IWL Motherboard Replacement: passo 18, immagine 2 di 2
    • Remove the three total silver 6 mm screws from the hinges of the screen in the top corners of the device using a Phillips #0 screwdriver.
  19. Lenovo IdeaPad S340-15IWL Motherboard Replacement: passo 19, immagine 1 di 3 Lenovo IdeaPad S340-15IWL Motherboard Replacement: passo 19, immagine 2 di 3 Lenovo IdeaPad S340-15IWL Motherboard Replacement: passo 19, immagine 3 di 3
    • Use an opening tool to flip up the hinges.
    • You may have to apply some force.
  20. Lenovo IdeaPad S340-15IWL Motherboard Replacement: passo 20, immagine 1 di 2 Lenovo IdeaPad S340-15IWL Motherboard Replacement: passo 20, immagine 2 di 2
    • Remove the three 3 mm screws holding the motherboard in place using a Phillips #0 screwdriver.
  21. Lenovo IdeaPad S340-15IWL Motherboard Replacement: passo 21, immagine 1 di 2 Lenovo IdeaPad S340-15IWL Motherboard Replacement: passo 21, immagine 2 di 2
    • Carefully unplug the black and red wires connected to the upper right corner of the motherboard.
    • These wires connect to the device’s charging port.
  22. Lenovo IdeaPad S340-15IWL Motherboard Replacement: passo 22, immagine 1 di 2 Lenovo IdeaPad S340-15IWL Motherboard Replacement: passo 22, immagine 2 di 2
    • Carefully lift the motherboard from the base of the computer and remove it from the laptop.
Conclusione
Altre 3 persone hanno completato questa guida.
Kristen Gismondi
Membro da: 11/12/14
92.630 Reputazione
241 Guide realizzate
iFixit Membro di iFixit
Staff
118 Membri
19.648 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 18
Ultimi 30 Giorni: 93
Tutti i Tempi: 3,482
