Salta al contenuto principale
Lenovo IdeaPad S210 Touch Cooling Fan Replacement
Cosa ti serve
  1. Lenovo IdeaPad S210 Touch Cooling Fan Replacement, Battery: passo 1, immagine 1 di 1
    • Ensure your device is unplugged and shut down.
    • Place the laptop down with the cooling vents facing upwards.
  2. Lenovo IdeaPad S210 Touch Cooling Fan Replacement: passo 2, immagine 1 di 2 Lenovo IdeaPad S210 Touch Cooling Fan Replacement: passo 2, immagine 2 di 2
    • Use your finger to slide the latch towards the unlocked position (away from the other latch). If done correctly you will see red.
    • Slide the second latch to the unlocked position while gently pulling the battery away from the laptop.
  3. Lenovo IdeaPad S210 Touch Cooling Fan Replacement, Back Panel: passo 3, immagine 1 di 2 Lenovo IdeaPad S210 Touch Cooling Fan Replacement, Back Panel: passo 3, immagine 2 di 2
    • Using the #0 Phillips screwdriver, remove the nine 4mm screws on the back panel.
  4. Lenovo IdeaPad S210 Touch Cooling Fan Replacement: passo 4, immagine 1 di 1
    • Gently pull the two rubber feet closest to battery away from the device. Using a #0 Phillips screwdriver, remove the 5mm screw under each rubber foot.
  5. Lenovo IdeaPad S210 Touch Cooling Fan Replacement: passo 5, immagine 1 di 3 Lenovo IdeaPad S210 Touch Cooling Fan Replacement: passo 5, immagine 2 di 3 Lenovo IdeaPad S210 Touch Cooling Fan Replacement: passo 5, immagine 3 di 3
    • Slowly begin working your plastic opening tool along the panel to undo the latches around the laptop.
  6. Lenovo IdeaPad S210 Touch Cooling Fan Replacement, Cooling Fan: passo 6, immagine 1 di 1
    • Many of the wire connections to the motherboard are secured by tape for vibration protection. Your device may or may not have this tape.
    • If any tape is present, remove all tape from the area within the red area.
  7. Lenovo IdeaPad S210 Touch Cooling Fan Replacement: passo 7, immagine 1 di 2 Lenovo IdeaPad S210 Touch Cooling Fan Replacement: passo 7, immagine 2 di 2
    • Using a #0 Phillips screwdriver, unscrew the four 3mm captive screws securing the copper tube onto the motherboard.
    • These captive screws are secured by plastic washer to the copper tube and will remain in the heat sink assembly during removal.
  8. Lenovo IdeaPad S210 Touch Cooling Fan Replacement: passo 8, immagine 1 di 3 Lenovo IdeaPad S210 Touch Cooling Fan Replacement: passo 8, immagine 2 di 3 Lenovo IdeaPad S210 Touch Cooling Fan Replacement: passo 8, immagine 3 di 3
    • Remove the tape connecting the copper tubing to the cooling fan.
    • Lift and remove the heat sink assembly.
  9. Lenovo IdeaPad S210 Touch Cooling Fan Replacement: passo 9, immagine 1 di 1
    • Using a #0 Phillips screwdriver, remove the three 3mm screws around the perimeter of the fan.
  10. Lenovo IdeaPad S210 Touch Cooling Fan Replacement: passo 10, immagine 1 di 2 Lenovo IdeaPad S210 Touch Cooling Fan Replacement: passo 10, immagine 2 di 2
    • Remove the wiring from the motherboard by gently pulling the wire connector at the base of the wires.
    • Once the wires are removed, the cooling fan assembly is disconnected. You may now remove the cooling fan.
Conclusione
Zack Colman
Membro da: 07/08/19
885 Reputazione
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 618
