Salta al contenuto principale
Lenovo IdeaPad S10-2 Hard Drive Replacement
Cosa ti serve
  1. Lenovo IdeaPad S10-2 Hard Drive Replacement, Hard Drive: passo 1, immagine 1 di 2 Lenovo IdeaPad S10-2 Hard Drive Replacement, Hard Drive: passo 1, immagine 2 di 2
    • Start with laptop closed.
    • Turn laptop over so the back panel is visible, as shown in the second image.
    • Remove the two 40 mm Phillips screws using a Phillips J0 head screwdriver.
  2. Lenovo IdeaPad S10-2 Hard Drive Replacement: passo 2, immagine 1 di 2 Lenovo IdeaPad S10-2 Hard Drive Replacement: passo 2, immagine 2 di 2
    • Remove both 40 mm Phillips screws using a Phillips J0 head screwdriver.
    • Remove the back panel and set it aside.
  3. Lenovo IdeaPad S10-2 Hard Drive Replacement: passo 3, immagine 1 di 2 Lenovo IdeaPad S10-2 Hard Drive Replacement: passo 3, immagine 2 di 2
    • Remove the 40 mm screw using a Phillips J0 head screwdriver.
  4. Lenovo IdeaPad S10-2 Hard Drive Replacement: passo 4, immagine 1 di 2 Lenovo IdeaPad S10-2 Hard Drive Replacement: passo 4, immagine 2 di 2
    • After removing the screw, carefully wedge the flat end of a spudger in the spacing to remove the hard drive from the port.
    • Pry the hard drive out of its port.
    • Push the wedged end of the spudger out as indicated by the action shots.
  5. Lenovo IdeaPad S10-2 Hard Drive Replacement: passo 5, immagine 1 di 2 Lenovo IdeaPad S10-2 Hard Drive Replacement: passo 5, immagine 2 di 2
    • Carefully lift the hard drive enclosure to remove it from the laptop.
    • The enclosure is the metal case holding the actual hard drive. You must remove the metal case in order to replace the hard drive.
  6. Lenovo IdeaPad S10-2 Hard Drive Replacement: passo 6, immagine 1 di 3 Lenovo IdeaPad S10-2 Hard Drive Replacement: passo 6, immagine 2 di 3 Lenovo IdeaPad S10-2 Hard Drive Replacement: passo 6, immagine 3 di 3
    • The hard drive enclosure has four 40 mm screws keeping the hard drive in place.
    • Remove the four 40 mm screws with a Phillips J0 head screwdriver.
  7. Lenovo IdeaPad S10-2 Hard Drive Replacement: passo 7, immagine 1 di 2 Lenovo IdeaPad S10-2 Hard Drive Replacement: passo 7, immagine 2 di 2
    • Slide the hard drive out of the enclosure.
    • The new hard drive can be inserted into the same enclosure.
Conclusione
Anthony
Membro da: 10/13/15
258 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 24
Tutti i Tempi: 9,500
