Parti
Nessuna parte richiesta.
To unlock the battery, flip the laptop over so that the bottom is facing upward. Then unlock the left clip by pushing the clip to the left.
  • To unlock the battery, flip the laptop over so that the bottom is facing upward. Then unlock the left clip by pushing the clip to the left.
Aggiungi Commento
Now push the right clip to the right and hold it while using your other hand to pull the battery out.
  • Now push the right clip to the right and hold it while using your other hand to pull the battery out.
Aggiungi Commento
  • Now remove the last two screws highlighted
Aggiungi Commento
  • Push hard drive away from the center of the chassis.
  • Lift the hard drive out of the chassis using the tab located on the drive.
Aggiungi Commento
  • Now push the little clips out away from the memory to unlock the memory.
Aggiungi Commento
  • After unlocking the memory from it's position, pull the memory out.
Aggiungi Commento
  • Remove three screws on bottom of case. They have a little keyboard image next to them. If you don't do this first, the keyboard will not come off. Place the plastic spudger right under the edge of the keyboard and lift up the keyboard.
Aggiungi Commento
  • Slowly and gently lift the keyboard up to separate from the chassis.
Aggiungi Commento
  • Gently lift the keyboard off the chassis.
  • Carefully disconnect the keyboard from the laptop by unhooking the keyboard ribbon.
Aggiungi Commento
  • Now remove the keyboard from the computer.
Aggiungi Commento
  • Pull the plug shown.
Aggiungi Commento
  • Lift up fan.
  • Remove two highlighted screws.
Aggiungi Commento
  • This is the fan separated from the motherboard.
Aggiungi Commento
Conclusione
Patrick
Membro da: 08/04/2014
427 Reputazione
3 Guide realizzate
Cal Poly, Team 8-7, Regan Spring 2014 Membro di Cal Poly, Team 8-7, Regan Spring 2014
CPSU-REGAN-S14S8G7
5 Membri
10 Guide realizzate
These instructions are incomplete. There are no steps to getting from removing the keyboard to getting to the fan. There may be more missing.
Clint Hatchett - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 8
Tutti i Tempi: 840
