Salta al contenuto principale
Lenovo IdeaPad N580 Battery Replacement
  1. Lenovo IdeaPad N580 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Turn over the device so that the bottom is facing up. Make sure the hinged side is facing you.
  2. Lenovo IdeaPad N580 Battery Replacement: passo 2, immagine 1 di 1
    • Move the right switch towards the right until it clicks in place. You should then see the color red reveal from where the switch was originally.
  3. Lenovo IdeaPad N580 Battery Replacement: passo 3, immagine 1 di 1
    • Now take your left hand and slide the left switch to the left.
    • This switch will not click in place like the other switch, so make sure to keep your left hand on the switch.
  4. Lenovo IdeaPad N580 Battery Replacement: passo 4, immagine 1 di 1
    • Take your free hand and place it on the battery. Gently slide it away from its slot.
Conclusione
Alex Amorim
Membro da: 03/19/18
907 Reputazione
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 308
