Salta al contenuto principale
Lenovo IdeaPad G50-45 Screen Replacement
Cosa ti serve
  1. Lenovo IdeaPad G50-45 Screen Replacement, Screen: passo 1, immagine 1 di 1
    • Remove the bezel by using the iFixit plastic opening tool to lift up an edge.
    • The bezel is the plastic lining along the edge of the screen.
  2. Lenovo IdeaPad G50-45 Screen Replacement: passo 2, immagine 1 di 1
    • Finish removing the bezel by using your hand on the inside of the screen and popping it off.
    • If part of the bezel is stuck, start on the opposite side and work your way back to the area that is stuck.
    • The plastic on the hinges will pop off with the rest of the bezel.
  3. Lenovo IdeaPad G50-45 Screen Replacement: passo 3, immagine 1 di 3 Lenovo IdeaPad G50-45 Screen Replacement: passo 3, immagine 2 di 3 Lenovo IdeaPad G50-45 Screen Replacement: passo 3, immagine 3 di 3
    • Remove the 4 screws located in each corner of the screen using the Phillips #2 screwdriver.
  4. Lenovo IdeaPad G50-45 Screen Replacement: passo 4, immagine 1 di 1
    • Peel back the sticker that attaches the connector to the back of the screen.
    • Disconnect the cable that connects the screen to the computer.
    • There may be two cables.
  5. Lenovo IdeaPad G50-45 Screen Replacement: passo 5, immagine 1 di 1
    • Test the new screen by turning it on before putting the bezel back on.
Conclusione
Altre 6 persone hanno completato questa guida.
UMass Dartmouth, Team 2-6, Shastany Fall 2015 Membro di UMass Dartmouth, Team 2-6, Shastany Fall 2015
UMASSD-SHASTANY-F15S2G6
3 Membri
5 Guide realizzate
2 Commenti
The tutorial was pretty straightforward, and worked.
Remy G - Replica
My Laptop is got work the searen is blue it what trun on
Rebecca - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 27
Tutti i Tempi: 7,845
