Salta al contenuto principale
Lenovo IdeaPad G50-45 Keyboard Replacement
Cosa ti serve
  1. Lenovo IdeaPad G50-45 Keyboard Replacement, Keyboard: passo 1, immagine 1 di 2 Lenovo IdeaPad G50-45 Keyboard Replacement, Keyboard: passo 1, immagine 2 di 2
    • Slide the two locking tabs away from each other to unlock the battery.
    • Remove the battery from the laptop once it is unlocked to prevent any electrical damage.
  2. Lenovo IdeaPad G50-45 Keyboard Replacement: passo 2, immagine 1 di 1
    • Locate the three M2x6 screws on the bottom of the laptop base.
    • Use the #2 Phillips screwdriver to loosen and remove each screw.
  3. Lenovo IdeaPad G50-45 Keyboard Replacement: passo 3, immagine 1 di 1
    • Slide the cover off and remove from the base.
  4. Lenovo IdeaPad G50-45 Keyboard Replacement: passo 4, immagine 1 di 2 Lenovo IdeaPad G50-45 Keyboard Replacement: passo 4, immagine 2 di 2
    • Locate the three M2x6 screws that secure the keyboard in place.
    • The screws are labeled with a keyboard emblem.
    • Loosen and unscrew the three M2x6 screws with the #2 Phillips screwdriver.
  5. Lenovo IdeaPad G50-45 Keyboard Replacement: passo 5, immagine 1 di 1
    • Turn the laptop right side up once the screws that secure the keyboard to the base have been removed.
    • Pry around the keyboard to loosen it apart from the laptop with the spudger, beginning at the top left corner.
    • You will hear audible "clicks" as the keyboard is separated from the base.
  6. Lenovo IdeaPad G50-45 Keyboard Replacement: passo 6, immagine 1 di 1
    • Lift the top of the keyboard up and forward once the top of the keyboard has been released.
    • Be VERY careful to remove the keyboard only a few inches to not damage the connecting ribbon cable.
  7. Lenovo IdeaPad G50-45 Keyboard Replacement: passo 7, immagine 1 di 1
    • Lift the black locking tab with the spudger to release the connecting ribbon cable.
    • Disconnect the ribbon cable by pulling it straight out.
    • Be careful to not damage the ribbon cable with the spudger.
  8. Lenovo IdeaPad G50-45 Keyboard Replacement: passo 8, immagine 1 di 1
    • Remove the keyboard after the ribbon cable is disconnected.
  9. Lenovo IdeaPad G50-45 Keyboard Replacement: passo 9, immagine 1 di 1
    • When installing the replacement keyboard, first insert the bottom of the keyboard into the three slots of the base.
    • Complete the keyboard installation by pressing down on the top of the keyboard until you hear the clips snap back into place.
Conclusione
Altre 8 persone hanno completato questa guida.
Saulo Gomes
Membro da: 10/26/15
601 Reputazione
2 Guide realizzate
UMass Dartmouth, Team 2-6, Shastany Fall 2015 Membro di UMass Dartmouth, Team 2-6, Shastany Fall 2015
UMASSD-SHASTANY-F15S2G6
3 Membri
5 Guide realizzate
Un commento
I had an issue with the numbers at the top of alphabets. Some keys didn't work. I followed the instructions above to clean up the keyboard and hoped that would work. I could successfully remove and reassemble the keyboard but that didn't solve it.
I read it somewhere that this could be a hardware issue and the whole keyboard needs to changed. Is it really the case? Can't few keys be changed or fixed somehow?
Thank you.
Pritam Patil - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 24
Tutti i Tempi: 12,662
