Salta al contenuto principale
Lenovo IdeaPad G50-45 Fan Replacement
Cosa ti serve
  1. Lenovo IdeaPad G50-45 Fan Replacement, Fan: passo 1, immagine 1 di 1
    • Safely flip the device upside down and use the Phillips head screwdriver to remove the 3 screws at the bottom of the device which are circled.
  2. Lenovo IdeaPad G50-45 Fan Replacement: passo 2, immagine 1 di 1
    • Slide, do not lift, the bottom panel off once the 3 screws are off.
  3. Lenovo IdeaPad G50-45 Fan Replacement: passo 3, immagine 1 di 1
    • Locate the fan in the upper right corner above the orange bar and appears as a silver semicircle.
  4. Lenovo IdeaPad G50-45 Fan Replacement: passo 4, immagine 1 di 2 Lenovo IdeaPad G50-45 Fan Replacement: passo 4, immagine 2 di 2
    • Remove the 3 screws attaching the fan to the device.
  5. Lenovo IdeaPad G50-45 Fan Replacement: passo 5, immagine 1 di 1
    • Once the screws are removed slowly lift the fan out, there will be a thin wire connected to the device and fan still, Firmly grasp the white end of the wire where the wire splits into 2 and pull it out.
  6. Lenovo IdeaPad G50-45 Fan Replacement: passo 6, immagine 1 di 1
    • The fan should be removed now and appear as so.
Conclusione
Altre 3 persone hanno completato questa guida.
Robert Muir
Membro da: 10/26/15
359 Reputazione
2 Guide realizzate
UMass Dartmouth, Team 2-6, Shastany Fall 2015 Membro di UMass Dartmouth, Team 2-6, Shastany Fall 2015
UMASSD-SHASTANY-F15S2G6
3 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 15
Tutti i Tempi: 2,937
