Salta al contenuto principale
Lenovo IdeaPad G50-45 DVD Drive Replacement
Cosa ti serve
  1. Lenovo IdeaPad G50-45 DVD Drive Replacement, DVD Drive: passo 1, immagine 1 di 1
    • First, remove the three screws located on the bottom panel of the laptop using a Philips #2 screwdriver.
    • To avoid losing the small screws, put them in a container.
  2. Lenovo IdeaPad G50-45 DVD Drive Replacement: passo 2, immagine 1 di 2 Lenovo IdeaPad G50-45 DVD Drive Replacement: passo 2, immagine 2 di 2
    • To remove the panel on the laptop, gently slide the panel away from the battery.
    • Make sure to slide the panel away before you lift to keep the panel from breaking.
    • Lift up the panel and place it to the side.
  3. Lenovo IdeaPad G50-45 DVD Drive Replacement: passo 3, immagine 1 di 2 Lenovo IdeaPad G50-45 DVD Drive Replacement: passo 3, immagine 2 di 2
    • Remove the indicated screw holding the DVD Drive.
    • To avoid losing the screw, place it in the same container used to hold the other three screws.
  4. Lenovo IdeaPad G50-45 DVD Drive Replacement: passo 4, immagine 1 di 1
    • Push the now-free tab towards the DVD Drive using a flathead screwdriver.
    • Do not pry up the now-free tab.
  5. Lenovo IdeaPad G50-45 DVD Drive Replacement: passo 5, immagine 1 di 1
    • Lastly, pull out the DVD Drive; it should come out easily.
Conclusione
Altre 6 persone hanno completato questa guida.
UMass Dartmouth, Team 2-6, Shastany Fall 2015 Membro di UMass Dartmouth, Team 2-6, Shastany Fall 2015
UMASSD-SHASTANY-F15S2G6
3 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 19
Tutti i Tempi: 8,441
