Salta al contenuto principale
Lenovo IdeaPad Flex 6-14IKB SSD Card Replacement
Cosa ti serve
  1. Lenovo IdeaPad Flex 6-14IKB SSD Card Replacement, Base Cover: passo 1, immagine 1 di 1
    • Remove the ten 6.5 mm screws that secure the base cover using a T5 Torx screwdriver.
  2. Lenovo IdeaPad Flex 6-14IKB SSD Card Replacement: passo 2, immagine 1 di 1
    • Use the plastic opening tool to pry in the seam between the bottom cover and the rest of the laptop.
    • The goal is to unhook the plastic hooks that secure the bottom cover.
    • Work your way around the bottom cover of the laptop in a clockwise rotation until every clip is free.
    • You will feel and hear a clicking noise when the clips are undone.
  3. Lenovo IdeaPad Flex 6-14IKB SSD Card Replacement, SSD Card: passo 3, immagine 1 di 1
    • Remove the single 3.5 mm screw that secures the SSD card using a Phillips #00 screwdriver.
  4. Lenovo IdeaPad Flex 6-14IKB SSD Card Replacement: passo 4, immagine 1 di 2 Lenovo IdeaPad Flex 6-14IKB SSD Card Replacement: passo 4, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Use tweezers to gently pry up the protective cover off of the SSD card.
  5. Lenovo IdeaPad Flex 6-14IKB SSD Card Replacement: passo 5, immagine 1 di 1
    • The SSD card will spring up to one side on its own.
  6. Lenovo IdeaPad Flex 6-14IKB SSD Card Replacement: passo 6, immagine 1 di 2 Lenovo IdeaPad Flex 6-14IKB SSD Card Replacement: passo 6, immagine 2 di 2
    • Remove the SSD from the motherboard.
    • When reinstalling the SSD, push the SSD card back into its slot. The SSD card will click into place when it is secure and then rest at a 30 degree angle from the laptop.
Conclusione
Altre 3 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 25
Tutti i Tempi: 1,129
