Salta al contenuto principale
Lenovo IdeaPad Flex 6-14IKB RAM Replacement
Cosa ti serve
  1. Lenovo IdeaPad Flex 6-14IKB RAM Replacement, Base Cover: passo 1, immagine 1 di 1
    • Remove the ten 6.5 mm screws that secure the base cover using a T5 Torx screwdriver.
  2. Lenovo IdeaPad Flex 6-14IKB RAM Replacement: passo 2, immagine 1 di 1
    • Use the plastic opening tool to pry in the seam between the bottom cover and the rest of the laptop.
    • The goal is to unhook the plastic hooks that secure the bottom cover.
    • Work your way around the bottom cover of the laptop in a clockwise rotation until every clip is free.
    • You will feel and hear a clicking noise when the clips are undone.
  3. Lenovo IdeaPad Flex 6-14IKB RAM Replacement, RAM: passo 3, immagine 1 di 1
    • Use the plastic opening tool to pry the protective cover off of the RAM.
  4. Lenovo IdeaPad Flex 6-14IKB RAM Replacement: passo 4, immagine 1 di 2 Lenovo IdeaPad Flex 6-14IKB RAM Replacement: passo 4, immagine 2 di 2
    • Unfasten the metal clips that secure the RAM.
  5. Lenovo IdeaPad Flex 6-14IKB RAM Replacement: passo 5, immagine 1 di 3 Lenovo IdeaPad Flex 6-14IKB RAM Replacement: passo 5, immagine 2 di 3 Lenovo IdeaPad Flex 6-14IKB RAM Replacement: passo 5, immagine 3 di 3
    • Remove the RAM from its slot on the motherboard.
Conclusione
Un commento
Thank you so much
Ayham Ka - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 30
Tutti i Tempi: 785
