Salta al contenuto principale
Lenovo IdeaPad Flex 6-14IKB Battery Replacement
Cosa ti serve
  1. Lenovo IdeaPad Flex 6-14IKB Battery Replacement, Base Cover: passo 1, immagine 1 di 1
    • Remove the ten 6.5 mm screws that secure the base cover using a T5 Torx screwdriver.
  2. Lenovo IdeaPad Flex 6-14IKB Battery Replacement: passo 2, immagine 1 di 1
    • Use the plastic opening tool to pry in the seam between the bottom cover and the rest of the laptop.
    • The goal is to unhook the plastic hooks that secure the bottom cover.
    • Work your way around the bottom cover of the laptop in a clockwise rotation until every clip is free.
    • You will feel and hear a clicking noise when the clips are undone.
  3. Lenovo IdeaPad Flex 6-14IKB Battery Replacement, Battery: passo 3, immagine 1 di 1
    • Remove the four 3.5 mm screws around the battery using a Phillips #00 screwdriver.
  4. Lenovo IdeaPad Flex 6-14IKB Battery Replacement: passo 4, immagine 1 di 2 Lenovo IdeaPad Flex 6-14IKB Battery Replacement: passo 4, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Disconnect the battery supply from the motherboard using a pair of tweezers.
    • Remove the battery from the laptop.
    • If the battery has an adhesive patch on the underside, gently pry off the battery.
Conclusione
Altre 7 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 20
Ultimi 30 Giorni: 83
Tutti i Tempi: 2,814
