Salta al contenuto principale
Lenovo IdeaPad Flex 6-14IKB Base Cover Replacement
Cosa ti serve
  1. Lenovo IdeaPad Flex 6-14IKB Base Cover Replacement, Base Cover: passo 1, immagine 1 di 1
    • Remove the ten 6.5 mm screws that secure the base cover using a T5 Torx screwdriver.
  2. Lenovo IdeaPad Flex 6-14IKB Base Cover Replacement: passo 2, immagine 1 di 1
    • Use the plastic opening tool to pry in the seam between the bottom cover and the rest of the laptop.
    • The goal is to unhook the plastic hooks that secure the bottom cover.
    • Work your way around the bottom cover of the laptop in a clockwise rotation until every clip is free.
    • You will feel and hear a clicking noise when the clips are undone.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 12
Tutti i Tempi: 302
