Salta al contenuto principale
Lenovo IdeaPad Flex 4-1470 Wifi Card Replacement
Cosa ti serve
  1. Lenovo IdeaPad Flex 4-1470 Wifi Card Replacement, Lower Case: passo 1, immagine 1 di 1
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the eight 6 mm screws using a Phillips #0 screwdriver.
    • Remove the two 11 mm screws using a Phillips #0 screwdriver.
  2. Lenovo IdeaPad Flex 4-1470 Wifi Card Replacement: passo 2, immagine 1 di 2 Lenovo IdeaPad Flex 4-1470 Wifi Card Replacement: passo 2, immagine 2 di 2
    • Pry the back cover off by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body.
    • Follow along the back edge with the plastic opening tool, lifting the cover off as you go. It is normal to hear snapping/clicking sounds as the back cover is held on by clips.
    • Remove the cover.
  3. Lenovo IdeaPad Flex 4-1470 Wifi Card Replacement, Wifi Card: passo 3, immagine 1 di 1
    • Remove the foam on the WIFI card.
  4. Lenovo IdeaPad Flex 4-1470 Wifi Card Replacement: passo 4, immagine 1 di 1
    • Remove the wires attached to the WIFI card.
  5. Lenovo IdeaPad Flex 4-1470 Wifi Card Replacement: passo 5, immagine 1 di 1
    • Unscrew the 4mm screw holding wifi card.
Conclusione
Elijah Ellis
Membro da: 11/08/18
616 Reputazione
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 12
Tutti i Tempi: 1,850
