Salta al contenuto principale
Lenovo IdeaPad Flex 4-1470 Touchpad Replacement
Cosa ti serve
  1. Lenovo IdeaPad Flex 4-1470 Touchpad Replacement, Lower Case: passo 1, immagine 1 di 1
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the eight 6 mm screws using a Phillips #0 screwdriver.
    • Remove the two 11 mm screws using a Phillips #0 screwdriver.
  2. Lenovo IdeaPad Flex 4-1470 Touchpad Replacement: passo 2, immagine 1 di 2 Lenovo IdeaPad Flex 4-1470 Touchpad Replacement: passo 2, immagine 2 di 2
    • Pry the back cover off by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body.
    • Follow along the back edge with the plastic opening tool, lifting the cover off as you go. It is normal to hear snapping/clicking sounds as the back cover is held on by clips.
    • Remove the cover.
  3. Lenovo IdeaPad Flex 4-1470 Touchpad Replacement, Battery: passo 3, immagine 1 di 2 Lenovo IdeaPad Flex 4-1470 Touchpad Replacement, Battery: passo 3, immagine 2 di 2
    • Disconnect the battery connector by using a plastic pry tool or your fingers to push the cable right towards the battery.
    • Do not pry or push on the socket itself or you risk damaging the motherboard.
  4. Lenovo IdeaPad Flex 4-1470 Touchpad Replacement: passo 4, immagine 1 di 1
    • Remove the three 4 mm Phillips #0 screws holding the battery in place.
  5. Lenovo IdeaPad Flex 4-1470 Touchpad Replacement: passo 5, immagine 1 di 1
    • Lift the battery up and out of the laptop.
  6. Lenovo IdeaPad Flex 4-1470 Touchpad Replacement, Touchpad: passo 6, immagine 1 di 1
    • Locate the touchpad.
  7. Lenovo IdeaPad Flex 4-1470 Touchpad Replacement: passo 7, immagine 1 di 2 Lenovo IdeaPad Flex 4-1470 Touchpad Replacement: passo 7, immagine 2 di 2
    • Remove the three ribbon cables surrounding the touch pad.
  8. Lenovo IdeaPad Flex 4-1470 Touchpad Replacement: passo 8, immagine 1 di 1
    • Lift the base of the laptop from the screen and gently push the touchpad to remove.
Conclusione
Altre 2 persone hanno completato questa guida.
Elijah Ellis
Membro da: 11/08/18
616 Reputazione
5 Guide realizzate
2 Commenti
do you know where to find this part? i have been looking everywhere haha.
Hanna Tafete - Replica
Can any body repair lenovo idea pad 1470. Touch screen ...tia
jgonzales - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 11
Tutti i Tempi: 1,203
