Salta al contenuto principale
Lenovo IdeaPad Flex 4-1470 Removing the Lower Case
Cosa ti serve
  1. Lenovo IdeaPad Flex 4-1470 Removing the Lower Case, Lower Case: passo 1, immagine 1 di 1
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the eight 6 mm screws using a Phillips #0 screwdriver.
    • Remove the two 11 mm screws using a Phillips #0 screwdriver.
  2. Lenovo IdeaPad Flex 4-1470 Removing the Lower Case: passo 2, immagine 1 di 2 Lenovo IdeaPad Flex 4-1470 Removing the Lower Case: passo 2, immagine 2 di 2
    • Pry the back cover off by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body.
    • Follow along the back edge with the plastic opening tool, lifting the cover off as you go. It is normal to hear snapping/clicking sounds as the back cover is held on by clips.
    • Remove the cover.
Conclusione
Altre 6 persone hanno completato questa guida.
USF Tampa, Team S1-G6, Thompson Fall 2017 Membro di USF Tampa, Team S1-G6, Thompson Fall 2017
USFT-THOMPSON-F17S1G6
3 Membri
10 Guide realizzate
Un commento
can someone please tell me where to find the back cover? i need to order it
angel etoile - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 22
Ultimi 30 Giorni: 72
Tutti i Tempi: 19,136
