Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Introduzione
This guide will show you how to remove the cover. This is a prerequisite guide for all other replacement guides on this page. It is also useful if you need to clean out dust that may be causing overheating.
Parti
Nessuna parte specificata.
  1. Ensure your computer is completely OFF before starting this guide.
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the eight 6 mm screws using a Phillips #0 screwdriver.
    • Remove the two 11 mm screws using a Phillips #0 screwdriver.
  2. Pry the back cover off by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body. Follow along the back edge with the plastic opening tool, lifting the cover off as you go. It is normal to hear snapping/clicking sounds as the back cover is held on by clips.
    • Pry the back cover off by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body.
    • Follow along the back edge with the plastic opening tool, lifting the cover off as you go. It is normal to hear snapping/clicking sounds as the back cover is held on by clips.
Conclusione
Altre 4 persone hanno completato questa guida.
USF Tampa, Team S1-G6, Thompson Fall 2017 Membro di USF Tampa, Team S1-G6, Thompson Fall 2017
USFT-THOMPSON-F17S1G6
3 Membri
6 Guide realizzate
can someone please tell me where to find the back cover? i need to order it
angel etoile - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 14
Ultimi 7 Giorni: 101
Ultimi 30 Giorni: 362
Tutti i Tempi: 5,371
