Salta al contenuto principale
Lenovo IdeaPad Flex 4-1470 Cmos battery Replacement
Cosa ti serve
  1. Lenovo IdeaPad Flex 4-1470 Cmos battery Replacement, Lower Case: passo 1, immagine 1 di 1
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the eight 6 mm screws using a Phillips #0 screwdriver.
    • Remove the two 11 mm screws using a Phillips #0 screwdriver.
  2. Lenovo IdeaPad Flex 4-1470 Cmos battery Replacement: passo 2, immagine 1 di 2 Lenovo IdeaPad Flex 4-1470 Cmos battery Replacement: passo 2, immagine 2 di 2
    • Pry the back cover off by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body.
    • Follow along the back edge with the plastic opening tool, lifting the cover off as you go. It is normal to hear snapping/clicking sounds as the back cover is held on by clips.
    • Remove the cover.
  3. Lenovo IdeaPad Flex 4-1470 Cmos battery Replacement, Cmos battery: passo 3, immagine 1 di 1
    • Using the JIS #0 screwdriver unscrew the three battery screws.
  4. Lenovo IdeaPad Flex 4-1470 Cmos battery Replacement: passo 4, immagine 1 di 1
    • Lift up the battery from the long, bottom edge.
    • Remove the battery from the laptop and place it nearby.
  5. Lenovo IdeaPad Flex 4-1470 Cmos battery Replacement: passo 5, immagine 1 di 2 Lenovo IdeaPad Flex 4-1470 Cmos battery Replacement: passo 5, immagine 2 di 2
    • Remove the red and black annotated cable, pulling white head out of black port as indicated.
  6. Lenovo IdeaPad Flex 4-1470 Cmos battery Replacement: passo 6, immagine 1 di 1
    • Ply the CMOS battery off with your finger.
    • The battery is attached to the computer by adhesive, but should come off by pulling with fingers; plying tool should not be necessary.
Conclusione
Altre 2 persone hanno completato questa guida.
Elijah Ellis
Membro da: 11/08/18
616 Reputazione
5 Guide realizzate
Un commento
Does this procedure reset the BIOS?
Mark Webb - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 14
Tutti i Tempi: 2,568
