Salta al contenuto principale
Lenovo IdeaPad Flex 4-1130 Battery Replacement
Cosa ti serve
  1. Lenovo IdeaPad Flex 4-1130 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Power off your Lenovo Ideapad Flex4-1130 before beginning disassembly.
    • Remove the ten 4mm screws from the back panel.
  2. Lenovo IdeaPad Flex 4-1130 Battery Replacement: passo 2, immagine 1 di 1
    • Insert the spudger into the groove work your way around the laptop to separate the bottom from the case.
    • Do not insert the spudger too deep! This could potentially damage a device part.
  3. Lenovo IdeaPad Flex 4-1130 Battery Replacement: passo 3, immagine 1 di 1
    • Remove the connector attaching the battery to the motherboard.
  4. Lenovo IdeaPad Flex 4-1130 Battery Replacement: passo 4, immagine 1 di 1
    • Remove the four 4mm screws on the battery.
  5. Lenovo IdeaPad Flex 4-1130 Battery Replacement: passo 5, immagine 1 di 1
    • Lift the battery with a spudger and remove.
Conclusione
USF Tampa, Team S17-G5, Boczar Spring 2018 Membro di USF Tampa, Team S17-G5, Boczar Spring 2018
USFT-BOCZAR-S18S17G5
3 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 11
Tutti i Tempi: 3,244
