Salta al contenuto principale
Lenovo IdeaPad Flex 3 CB 11M735 Touchpad Replacement
Cosa ti serve
  1. Lenovo IdeaPad Flex 3 CB 11M735 Touchpad Replacement, Lenovo IdeaPad Flex 3 CB 11M735 Disassembly: passo 1, immagine 1 di 2 Lenovo IdeaPad Flex 3 CB 11M735 Touchpad Replacement, Lenovo IdeaPad Flex 3 CB 11M735 Disassembly: passo 1, immagine 2 di 2
    • It's best to touch the ground before you start to be sure you won't shock any components.
    • Use a T6 Torx screwdriver to unscrew the nine M2 x 6.5mm screws.
  2. Lenovo IdeaPad Flex 3 CB 11M735 Touchpad Replacement: passo 2, immagine 1 di 3 Lenovo IdeaPad Flex 3 CB 11M735 Touchpad Replacement: passo 2, immagine 2 di 3 Lenovo IdeaPad Flex 3 CB 11M735 Touchpad Replacement: passo 2, immagine 3 di 3
    • Using a plastic spudger, carefully lift the palmrest from the bottom cover.
    • Be careful while removing the keyboard, and unplug the connections.
  3. Lenovo IdeaPad Flex 3 CB 11M735 Touchpad Replacement, Keyboard: passo 3, immagine 1 di 2 Lenovo IdeaPad Flex 3 CB 11M735 Touchpad Replacement, Keyboard: passo 3, immagine 2 di 2
    • Unfortunately, the keyboard is secured using melted plastic pins on the back plate of the keyboard, which cannot be redone, making the repair easy but not very environmentally friendly.
    • The pieces are mostly secured with glue and melted plastic, making it impossible to put them back to getter after opening them.
    • That there is a barcode on some parts that, when scanned, will you to available replacement parts.
  4. Lenovo IdeaPad Flex 3 CB 11M735 Touchpad Replacement: passo 4, immagine 1 di 3 Lenovo IdeaPad Flex 3 CB 11M735 Touchpad Replacement: passo 4, immagine 2 di 3 Lenovo IdeaPad Flex 3 CB 11M735 Touchpad Replacement: passo 4, immagine 3 di 3
    • The two indicated attachments allow the keyboard and touchpad to be plugged into the motherboard. The red circle indicates the place for the touchpad, and the red rectangle shows the place for the keyboard wire.
    • The black plastic piece that holds the wire in place needs to be closed while covering the whole wire.
  5. Lenovo IdeaPad Flex 3 CB 11M735 Touchpad Replacement: passo 5, immagine 1 di 1
    • Place the keyboard back in the right place and gently push until you hear a crunching sound. Press all around the keyboard until the crunching sound stops as you push it.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 126
