Salta al contenuto principale
Lenovo IdeaPad Flex 3 CB 11M735 Charging Port Replacement
Cosa ti serve
  1. Lenovo IdeaPad Flex 3 CB 11M735 Charging Port Replacement, Lenovo IdeaPad Flex 3 CB 11M735 Disassembly: passo 1, immagine 1 di 2 Lenovo IdeaPad Flex 3 CB 11M735 Charging Port Replacement, Lenovo IdeaPad Flex 3 CB 11M735 Disassembly: passo 1, immagine 2 di 2
    • It's best to touch the ground before you start to be sure you won't shock any components.
    • Use a T6 Torx screwdriver to unscrew the nine M2 x 6.5mm screws.
  2. Lenovo IdeaPad Flex 3 CB 11M735 Charging Port Replacement: passo 2, immagine 1 di 3 Lenovo IdeaPad Flex 3 CB 11M735 Charging Port Replacement: passo 2, immagine 2 di 3 Lenovo IdeaPad Flex 3 CB 11M735 Charging Port Replacement: passo 2, immagine 3 di 3
    • Using a plastic spudger, carefully lift the palmrest from the bottom cover.
    • Be careful while removing the keyboard, and unplug the connections.
  3. Lenovo IdeaPad Flex 3 CB 11M735 Charging Port Replacement, Charging Port: passo 3, immagine 1 di 1
    • Start with your PH00 screwdriver and remove all of the 7x(M2x4.5mm) indicated screws. These screws keep the screen in place.
    • The marked cord needs to be disconnected too, this is the screen cord to the motherboard.
  4. Lenovo IdeaPad Flex 3 CB 11M735 Charging Port Replacement: passo 4, immagine 1 di 1
    • There are a total of 9x(M2x4) more screws that connect the motherboard into its place that needs to be removed.orange. Opening it will show that this device's motherboard had to be repaired.
    • One of these screws is hidden under a small Lenovo sticker which is marked orange. Opening it will show that this device's motherboard had to be repaired.
    • All of the screws in the motherboard that secures it to the place are marked with a small triangle that helps you to put the right screws back on for reassembling since some holes are meant to be screwed multiple layers together.
    • The two rectangles are two cords that attach the main motherboard to the side motherboards. The blue rectangle needs to be disconnected for our purpose.
  5. Lenovo IdeaPad Flex 3 CB 11M735 Charging Port Replacement: passo 5, immagine 1 di 3 Lenovo IdeaPad Flex 3 CB 11M735 Charging Port Replacement: passo 5, immagine 2 di 3 Lenovo IdeaPad Flex 3 CB 11M735 Charging Port Replacement: passo 5, immagine 3 di 3
    • As you can see, after the last step, you can easily remove the motherboard.
    • Plug your soldering device and set it to around 350°F.
    • Make sure you don't burn yourself. Also, use the proper stand and avode placing your soldering device on anything flamable.
    • Flip the motherboard and start desoldering the little wholes with the tip of your hot soldering device. This will melt the solder and let you remove the USB-C.
    • Put your new USB 3.1 Type-C 16pin Femalein place, and melt down the solder so it attaches to the motherboard.
Conclusione
To reassemble your device, follow the instruction.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 30
Tutti i Tempi: 355
