Salta al contenuto principale
Lenovo IdeaPad Flex 3 CB 11M735 Battery Replacement
Cosa ti serve
  1. Lenovo IdeaPad Flex 3 CB 11M735 Battery Replacement, Lenovo IdeaPad Flex 3 CB 11M735 Disassembly: passo 1, immagine 1 di 2 Lenovo IdeaPad Flex 3 CB 11M735 Battery Replacement, Lenovo IdeaPad Flex 3 CB 11M735 Disassembly: passo 1, immagine 2 di 2
    • It's best to touch the ground before you start to be sure you won't shock any components.
    • Use a T6 Torx screwdriver to unscrew the nine M2 x 6.5mm screws.
  2. Lenovo IdeaPad Flex 3 CB 11M735 Battery Replacement: passo 2, immagine 1 di 3 Lenovo IdeaPad Flex 3 CB 11M735 Battery Replacement: passo 2, immagine 2 di 3 Lenovo IdeaPad Flex 3 CB 11M735 Battery Replacement: passo 2, immagine 3 di 3
    • Using a plastic spudger, carefully lift the palmrest from the bottom cover.
    • Be careful while removing the keyboard, and unplug the connections.
  3. Lenovo IdeaPad Flex 3 CB 11M735 Battery Replacement, Battery: passo 3, immagine 1 di 1
    • Disconnecting the battery from the motherboard.
  4. Lenovo IdeaPad Flex 3 CB 11M735 Battery Replacement: passo 4, immagine 1 di 1
    • Use a PH00 screwdriver to remove the 3x(M2x4mm) screws.
  5. Lenovo IdeaPad Flex 3 CB 11M735 Battery Replacement: passo 5, immagine 1 di 1
    • Ensure the replacement battery is right, then follow the steps backward to assemble everything.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 33
Tutti i Tempi: 392
