Salta al contenuto principale
Lenovo IdeaPad FLEX 4-1580 Fan Replacement
Cosa ti serve
  1. Lenovo IdeaPad FLEX 4-1580 Fan Replacement, Battery: passo 1, immagine 1 di 1
    • Flip laptop over so the model sticker is showing, and begin to unscrew all of the screws.
  2. Lenovo IdeaPad FLEX 4-1580 Fan Replacement: passo 2, immagine 1 di 1
    • Pop off the back panel using a plastic opening tool once all screws are removed.
  3. Lenovo IdeaPad FLEX 4-1580 Fan Replacement: passo 3, immagine 1 di 1
    • Once the panel is fully removed, begin to unscrew the battery.
  4. Lenovo IdeaPad FLEX 4-1580 Fan Replacement: passo 4, immagine 1 di 2 Lenovo IdeaPad FLEX 4-1580 Fan Replacement: passo 4, immagine 2 di 2
    • Use the iFixit Opening tool to disconnect the battery from the circuit board.
    • When all screws are removed from the battery, carefully lift the battery up.
  5. Lenovo IdeaPad FLEX 4-1580 Fan Replacement: passo 5, immagine 1 di 1
    • The battery is completely removed, and can be replaced with a new battery.
  6. Lenovo IdeaPad FLEX 4-1580 Fan Replacement, Fan: passo 6, immagine 1 di 1
    • Remove all screws securing the fan to the laptop.
  7. Lenovo IdeaPad FLEX 4-1580 Fan Replacement: passo 7, immagine 1 di 1
    • Unhook the wire from the fan component using a spudger.
  8. Lenovo IdeaPad FLEX 4-1580 Fan Replacement: passo 8, immagine 1 di 1
    • Now the fan is completely removed.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 422
