Salta al contenuto principale
Lenovo IdeaPad A1-07 Battery Replacement
Cosa ti serve
  1. Lenovo IdeaPad A1-07 Battery Replacement, Back Cover/Midframe: passo 1, immagine 1 di 3 Lenovo IdeaPad A1-07 Battery Replacement, Back Cover/Midframe: passo 1, immagine 2 di 3 Lenovo IdeaPad A1-07 Battery Replacement, Back Cover/Midframe: passo 1, immagine 3 di 3
    • With the blue plastic opening tool, use the lock screen switch by the volume button as an access point to gently lift the back cover off.
    • Wedge the opening tool until you start hearing the back cover popping off the body of the device.
    • Slide the opening tool down the length of the device.
    • Once it is about half way off, you can use your thumb to pull the rest of the back cover off.
  2. Lenovo IdeaPad A1-07 Battery Replacement: passo 2, immagine 1 di 3 Lenovo IdeaPad A1-07 Battery Replacement: passo 2, immagine 2 di 3 Lenovo IdeaPad A1-07 Battery Replacement: passo 2, immagine 3 di 3
    • Using a Phillips #000 screwdriver, remove all 18 of the 4mm screws.
    • With the blue plastic opening tool, gently wedge the tool between the screen and the gray frame until you feel resistance.
    • Do not force the frame off because you can break off the teeth securing the frame to the screen.
    • Push in the teeth with the blue plastic opening tool, towards the center of the device, and gently pull off the frame.
    • The gray frame will still be connected to the device by a pair of wires from the motherboard to the speaker.
  3. Lenovo IdeaPad A1-07 Battery Replacement: passo 3, immagine 1 di 2 Lenovo IdeaPad A1-07 Battery Replacement: passo 3, immagine 2 di 2
    • The speaker in the grey frame is connected to the motherboard by the white plastic connector.
    • Disconnect the speaker by separating the two sides of the speaker connector.
  4. Lenovo IdeaPad A1-07 Battery Replacement, Battery: passo 4, immagine 1 di 3 Lenovo IdeaPad A1-07 Battery Replacement, Battery: passo 4, immagine 2 di 3 Lenovo IdeaPad A1-07 Battery Replacement, Battery: passo 4, immagine 3 di 3
    • Use a plastic opening tool to push the white battery connector out of its socket on the motherboard.
    • Lift the battery away from the device.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 833
