Introduzione
If you are struggling with the touch pad working and responsivity of the touchpad follow the guide below to replace the touch with a new one.
Cosa ti serve
Remove the ten 3.3 mm screws securing the back panel using a Phillips #00 screwdriver.
Use a Jimmy or your fingernail to pry the back panel off.
Remove the five 3 mm screws securing the battery using a Phillips #00 screwdriver.
Remove the six 3 mm screws from the black board using a Phillips #00 screwdriver.
Remove the black board.
Remove three 3 mm screws connecting the motherboard to the frame of the laptop.
