Salta al contenuto principale
Lenovo IdeaPad 330S Wireless Lan Card Replacement
Cosa ti serve
  1. Lenovo IdeaPad 330S Wireless Lan Card Replacement, Removing Bottom Case: passo 1, immagine 1 di 2 Lenovo IdeaPad 330S Wireless Lan Card Replacement, Removing Bottom Case: passo 1, immagine 2 di 2
    • Turn the device off.
    • Remove the 10 screws as shown in picture.
    • Using a pry tool , remove the bottom case.
  2. Lenovo IdeaPad 330S Wireless Lan Card Replacement, Disconnecting Battery: passo 2, immagine 1 di 1
    • Using a spudger gently push the plastic connector to the left in order to disconnect the battery.
  3. Lenovo IdeaPad 330S Wireless Lan Card Replacement, Removing guard shield: passo 3, immagine 1 di 1
    • Remove the three 00# screws.
    • Remove the 2.5 mm screw.
    • Gently pry the shield.
  4. Lenovo IdeaPad 330S Wireless Lan Card Replacement, Removing Wireless Card: passo 4, immagine 1 di 1
    • Before removing the screw (marked in red circle) remove the two antenna cables using the spudger.
    • Remove the screw.
    • The wireless card will lift, remove it.
    • Install the new wireless card.
Conclusione
Ilia Tocheny
Membro da: 04/30/19
1.616 Reputazione
9 Guide realizzate
2 Commenti
So my laptop sometimes has no bluetooth, or wifi, or both. A quick reboot fixes it, but idk if the module is actually faulty. I've opened it before, and don't want to buy a replacement chip if this one is just seated poorly. Is there a good way to check. Thanks
Calvin Mills - Replica
Using the correct tools try to disconnect the cables from the socket and reseat them in the socket make just do as the guide but without removing the WLAN card
Ilia Tocheny -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 47
Tutti i Tempi: 3,323
