Salta al contenuto principale
Lenovo IdeaPad 330S RAM Replacement
Cosa ti serve
  1. Lenovo IdeaPad 330S RAM Replacement, Removing bottom case: passo 1, immagine 1 di 2 Lenovo IdeaPad 330S RAM Replacement, Removing bottom case: passo 1, immagine 2 di 2
    • Please turn off the laptop before opening the device
    • Remove the 10 screws as shown in the picture.
    • Gently using the tool pry off the bottom case
  2. Lenovo IdeaPad 330S RAM Replacement, Disconnecting Battery: passo 2, immagine 1 di 1
    • Using a spudger gently push the plastic connector to the left in order to disconnect the battery. wisdom here.
  3. Lenovo IdeaPad 330S RAM Replacement, Removing Black Case: passo 3, immagine 1 di 2 Lenovo IdeaPad 330S RAM Replacement, Removing Black Case: passo 3, immagine 2 di 2
    • Remove these screws as show in picture
    • Gently pry out the black case.
    • Note that one of the screws are Philips 2.5 and not Philips (the black screw top right ).
  4. Lenovo IdeaPad 330S RAM Replacement, Removing Ram Stick: passo 4, immagine 1 di 1
    • Gently using heavy duty spuder remove the old memory
  5. Lenovo IdeaPad 330S RAM Replacement, Installing Ram Stick: passo 5, immagine 1 di 1
    • Arrange the new ram stick accoring the pin on the motherboard
    • Push Gently on the stick until you hear two clicks
Conclusione
To reassemble the device, install your new stick(s) and follow these instructions in reverse order.
Altre 6 persone hanno completato questa guida.
Ilia Tocheny
Membro da: 04/30/19
1.667 Reputazione
9 Guide realizzate
8Commenti sulla guida
Is it possible to upgrade the cpu of my lenovo 330s which is a core i3 7gen to say a core i5 10th gen
Nathan D'souza - Replica
Only by replacement or the Motherboard…
The CPU is soldered to the M.B. and cannot upgraded easily
Ilia Tocheny - Replica
Hallo.
I am Japanese Hegt Stuident.
Do I need to remove the battery when removing the RAM?
(こんにちは。
日本の高校生です。
RAMを外すとき、バッテリーは外す必要がありますか?)
Muromi - Replica
You can disconnect the battery no need of removing it.
Ilia Tocheny -
I just Updated the repair guide of memory replacement.
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 26
Ultimi 30 Giorni: 103
Tutti i Tempi: 8,215
