Salta al contenuto principale
Lenovo IdeaPad 330S NVMe Drive Replacement
Cosa ti serve
  1. Lenovo IdeaPad 330S NVMe Drive Replacement, NVMe Drive/Sata SSD: passo 1, immagine 1 di 2 Lenovo IdeaPad 330S NVMe Drive Replacement, NVMe Drive/Sata SSD: passo 1, immagine 2 di 2
    • Turn off the device before working on it.
    • Remove the 10 screws as shown in the picture
    • Gently using the tool pry off the bottom case
  2. Lenovo IdeaPad 330S NVMe Drive Replacement, Disconnecting Battery: passo 2, immagine 1 di 1
    • Using a spudger gently push the plastic connector to the left in order to disconnect the battery.
  3. Lenovo IdeaPad 330S NVMe Drive Replacement: passo 3, immagine 1 di 1
    • Remove the 4 screws according this picture
    • Gently pry out the black case.
    Before removing the case, for safety you have to disconnect the battery cable, otherwise you may damage the motherboard when you touch it with the case.
    Gastón Luna - Replica
    This guide at step 2 reminds to disconcert the battery.
    Ilia Tocheny - Replica
  4. Lenovo IdeaPad 330S NVMe Drive Replacement: passo 4, immagine 1 di 1
    • Remove the Screw as shown in picture
    • The drive will lift, remove gently the drive.
    • Install the new drive and screw it to the motherboard
    Which of these (NVMe SSD and SATA SSD) is compatible for this device?
    Chinmay Sahu - Replica
Conclusione
Altre 5 persone hanno completato questa guida.
Ilia Tocheny
Membro da: 04/30/19
1.667 Reputazione
9 Guide realizzate
7Commenti sulla guida
Is this machine compatible with both NVMe SSD and SATA SSD on the M2 port? Thank you.
notyourITguy - Replica
This machine is compatible NVMe and Sata drive.
Ilia Tocheny -
mine came with m2 2242 ssd and is reaching its lifespan, can I replace it with m2 2280?
Kaizoku 62 - Replica
Yes you can but before you do this… make sure to backup all data before doing the upgrade. When you will install the new ssd make you sure it is Nvme gen 3 and not gen4.
Samsung 980 is recommended ssd for the upgrade…
any reason why I cannot install nvme gen4? its the same price as gen3
isnt it backwards compatible?
Kaizoku 62 -
Yes and no.
It’s backward compatible when the board supports Gen4 and you install Gen3 but what you are talking is called “forward compatibility “ and it is basically don’t exist.
I think you are mistaken. Backwards compatibility means the gen4 nvme will still run but limited to the board's supported hardware capability, which is gen3 only. So my gen4 nvme will run at gen3 speeds.
I have since installed a gen4 nvme onto my 330S already and it works fine.
Kaizoku 62 -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 71
Tutti i Tempi: 5,648
