Salta al contenuto principale
Lenovo IdeaPad 330S Battery Replacement
Cosa ti serve
  1. Lenovo IdeaPad 330S Battery Replacement, Removing bottom panel: passo 1, immagine 1 di 2 Lenovo IdeaPad 330S Battery Replacement, Removing bottom panel: passo 1, immagine 2 di 2
    • Turn off the device and disconnect it from the power supply.
    • Remove the 10 screws as shown in picture.
    • Using an opening tool pry off the bottom case.
  2. Lenovo IdeaPad 330S Battery Replacement: passo 2, immagine 1 di 1
    • Disconnect the battery by gently pushing the black connector to the left. (Marked in blue).
    • Remove the 5 screws that are marked in red.
    • Install the new battery.
Conclusione
Altre 3 persone hanno completato questa guida.
Ilia Tocheny
Membro da: 04/30/19
1.616 Reputazione
9 Guide realizzate
6 Commenti
Make sure you check if your replacement battery is the 12.25v or the 7.4v. This laptop could have came with either.
Nick Aspinwall - Replica
Actually you could to upgrade your battery from 43 WHR to 52.5 WHR but this requiring little bit research…
Ilia Tocheny -
So is there a battery shaped similarly that will increase the battery life? My laptop will only last about 2 hours.
patrick charles - Replica
Hi, is your battery is 52.5 Whr? Is it orginal?
If the answer to both is yes, I would recommend to replace the battery because it might be dying (wearing).
but before you change it check with the lenovo support what battery can you buy.
(support lenovo-register-detect device-parts-recharble batteries)
if that doesnt help you can always ask lenovo support specialist
Ilia Tocheny -
my 330s 15arr came with a 30wh battery and is quite degraded now lasting less than 2hrs, can I replace it with a 52wh battery? the size and mounting tabs look exactly the same
Kaizoku 62 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 32
Ultimi 30 Giorni: 217
Tutti i Tempi: 14,928
