Salta al contenuto principale
Lenovo IdeaPad 330-15IKB 81DE Speaker Replacement
Cosa ti serve
  1. Lenovo IdeaPad 330-15IKB 81DE Speaker Replacement, Back Panel: passo 1, immagine 1 di 3 Lenovo IdeaPad 330-15IKB 81DE Speaker Replacement, Back Panel: passo 1, immagine 2 di 3 Lenovo IdeaPad 330-15IKB 81DE Speaker Replacement, Back Panel: passo 1, immagine 3 di 3
    • Ensure the laptop is powered off.
    • Turn the device over so the bottom is facing up.
    • Remove the 13 6 mm screws from the bottom of the device using a Phillips #0 screwdriver.
    • Carefully glide a Jimmy along the seam of the casing.
    • Remove the back cover of the laptop.
  2. Lenovo IdeaPad 330-15IKB 81DE Speaker Replacement, Battery: passo 2, immagine 1 di 3 Lenovo IdeaPad 330-15IKB 81DE Speaker Replacement, Battery: passo 2, immagine 2 di 3 Lenovo IdeaPad 330-15IKB 81DE Speaker Replacement, Battery: passo 2, immagine 3 di 3
    • Remove the three 6 mm screws from the tabs surrounding the battery using a Phillips #0 screwdriver.
    • Carefully separate the battery connector from the device using a spudger.
    • Lift the battery up and remove it from the device.
  3. Lenovo IdeaPad 330-15IKB 81DE Speaker Replacement, Speaker: passo 3, immagine 1 di 3 Lenovo IdeaPad 330-15IKB 81DE Speaker Replacement, Speaker: passo 3, immagine 2 di 3 Lenovo IdeaPad 330-15IKB 81DE Speaker Replacement, Speaker: passo 3, immagine 3 di 3
    • Remove the connector for the speakers from the motherboard using a spudger.
    • Gently lift the speakers from the device using a spudger.
    • Carefully lift the red wire from its dock along the bottom.
    • Remove the speakers from the device.
Conclusione
Matthew Bridge
Membro da: 10/18/24
245 Reputazione
2 Guide realizzate
UMass Dartmouth, Team 2-1, Konn Fall 2024 Membro di UMass Dartmouth, Team 2-1, Konn Fall 2024
UMASSD-KONN-F24S2G1
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 29
Tutti i Tempi: 104
