Salta al contenuto principale
Lenovo IdeaPad 300-17ISK Wireless LAN Card Replacement
Cosa ti serve
  1. Lenovo IdeaPad 300-17ISK Wireless LAN Card Replacement, Bottom Back Cover: passo 1, immagine 1 di 1
    • Unscrew the two 7mm Phillips #1 screws that hold the bottom back plate in its place.
  2. Lenovo IdeaPad 300-17ISK Wireless LAN Card Replacement: passo 2, immagine 1 di 2 Lenovo IdeaPad 300-17ISK Wireless LAN Card Replacement: passo 2, immagine 2 di 2
    • Place your hands at the bottom of the cover and slide it towards you.
    • Lift the cover up to remove it.
  3. Lenovo IdeaPad 300-17ISK Wireless LAN Card Replacement, Wireless LAN Card: passo 3, immagine 1 di 1
    • The wireless LAN card is located at the center of the laptop.
  4. Lenovo IdeaPad 300-17ISK Wireless LAN Card Replacement: passo 4, immagine 1 di 1
    • Unscrew the 3mm Phillips #1 screw that holds the WLAN card in place.
  5. Lenovo IdeaPad 300-17ISK Wireless LAN Card Replacement: passo 5, immagine 1 di 1
    • Disconnect the black and white cables from the WLAN card.
  6. Lenovo IdeaPad 300-17ISK Wireless LAN Card Replacement: passo 6, immagine 1 di 1
    • Gently remove the WLAN card out of its slot.
Conclusione
Altre 3 persone hanno completato questa guida.
Ammar Dodin
Membro da: 01/19/17
1.057 Reputazione
6 Guide realizzate
UC Davis, Team 1-3, Rodger Winter 2017 Membro di UC Davis, Team 1-3, Rodger Winter 2017
UCD-RODGER-W17S1G3
4 Membri
6 Guide realizzate
3 Commenti
Thanks Ammar, I thought my wifi card was jammed until I saw your post.
Turns out one of the cables (white one) was disconnected which lead to my wifi signal being non-existent. I plugged it in again and its working properly again.
Cheers
Vlottie
David Vlotman - Replica
Thanks for say, white is 1
SABBIR HOSSAIN -
How to connect wire black and white to pin 1 and 2, plz help
SABBIR HOSSAIN - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 16
Tutti i Tempi: 2,798
