Salta al contenuto principale
Lenovo IdeaPad 300-17ISK RAM Replacement
Cosa ti serve
  1. Lenovo IdeaPad 300-17ISK RAM Replacement, Bottom Back Cover: passo 1, immagine 1 di 1
    • Unscrew the two 7mm Phillips #1 screws that hold the bottom back plate in its place.
  2. Lenovo IdeaPad 300-17ISK RAM Replacement: passo 2, immagine 1 di 2 Lenovo IdeaPad 300-17ISK RAM Replacement: passo 2, immagine 2 di 2
    • Place your hands at the bottom of the cover and slide it towards you.
    • Lift the cover up to remove it.
  3. Lenovo IdeaPad 300-17ISK RAM Replacement, RAM: passo 3, immagine 1 di 1
    • The RAM sticks are located near the bottom of the device, and they are arranged next to each other.
  4. Lenovo IdeaPad 300-17ISK RAM Replacement: passo 4, immagine 1 di 3 Lenovo IdeaPad 300-17ISK RAM Replacement: passo 4, immagine 2 di 3 Lenovo IdeaPad 300-17ISK RAM Replacement: passo 4, immagine 3 di 3
    • Locate the two dislocating latches on each side of the stick and place your fingers on them.
    • Pull the tabs away from the stick simultaneously until the stick pops out of place.
    • Gently remove the RAM stick once it has popped out of its place.
    • If necessary, repeat the same process with the second RAM stick that is adjacent to the first one.
Conclusione
To reassemble the device, install your new stick(s) and follow these instructions in reverse order.
Ammar Dodin
Membro da: 01/19/17
1.057 Reputazione
6 Guide realizzate
UC Davis, Team 1-3, Rodger Winter 2017 Membro di UC Davis, Team 1-3, Rodger Winter 2017
UCD-RODGER-W17S1G3
4 Membri
6 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 31
Tutti i Tempi: 2,712
